Where To Get Gas Shock?
  • BHog
    • Dec 2006
    • 207
    • Rockwall, TX
    I need a new gas shock for my golve box. At one time there was a link to buy mis nautique boat parts Any info will be appreciated.
  • hourglass
    • Mar 2010
    • 248
    • lower bama
    • 2005 SANTE
    you can try orlandonautiques.com or probably skidim
    • BrennanK
      • Feb 2009
      • 348
      • Hopkins, MN
      I got a 30 LB one at Nappa, the stock one is 20LB. You can also get them at Nautique Parts.
      1997 Ski Nautique
      • TRO
        • Mar 2009
        • 410
        • Houston, TX
        BHHog:
        I have ordered a number of gas shocks from NautiqueParts.com (White Lake Marine), including a glove box shock. Their customer service is off the hook and they ship fast. There is a link to their site on the main page of the forums and you get a discount for being a member of Planet Nautique.
        I highly recommend them.
        the discount code is PND and here is a link to some info about them.
        http://planetnautique.com/vb3/entry....te-Lake-Marine
        • obd666
          • Feb 2010
          • 793
          • Bostian Heights, NC
          • 03 SANTE
          the shipping aside, will be much cheaper from nautique parts. the one i got from napa was over thirty bucks
          2003 SANTE - "OG 210"
          • Flipside
            • Feb 2009
            • 137
            • Portland, OR
            White Lake Marine has them.
            West Marine has them (not sure if you have this store in TX).
            Otherwise you can order them direct through Attwood:
            http://www.attwoodmarine.com/store/category/gas-springs
            The glove box ones are 20 lbs force.
            • bumpin
              • Oct 2008
              • 10
              I just bought some at NAPA
              I put a NAPA brand 20lb gas shock on the glove box and it works but doesn't have a lot of extra hold. The glove box lid is actually pretty heavy for it's size.
              • Flipside
                • Feb 2009
                • 137
                • Portland, OR
                I replaced mine with a 30 lb gas spring and my glove box closes like a crocodile's mouth! Make sure your fingers are nowhere near! But it has no problem holding up the lid that's for sure.
                • Proud2BeCC
                  • Mar 2004
                  • 201
                  • Warsaw, IN
                  • 2002 Sport Nautique
                  Got mine from N3 Boatworks. Great guys...Was cheap, and was delivered quickly.
                  http://www.n3boatworks.com/eshopitem...Gas_Shocks.htm
                  _____________________________________________
                  Proud2BeCC
                  2002 Sport Nautique
                  (NDT) New Dimension Tower
                  TowerBinimi Binimi Top
                  Clarion CMD5
                    • 2908
                    I bought a 30lb 7.5" shock from this guy: strut-your-stuff@clearwire.net
                    He sells struts on ebay, I bought it directly from him. It works significantly better than the factory unit. I also relocated the lower stationary ball mount so it doesn't snap down on unsuspecting fingers like it does with the factory location. Moved the ball as low as possible in the glove box so it is constantly pushing up on the lid. Works much better now. I don't mind the extra screw holes inside my glove box.
