GT-40 Oil Weight
  • BrennanK
    • Feb 2009
    • 348
    • Hopkins, MN
    GT-40 Oil Weight
    What kind and weight oil do you guys use in your GT-40's? On the info panel it says straight 40 weight oil, and that seems a little heavy.
    There was a thread about this recently, but for the Excalibur engines.
    I would have searched the forums but it disregards words 3 letters or shorter.
    Thanks.
    1997 Ski Nautique
  • 74green
    • Nov 2009
    • 281
    • Canyon Lake, Texas
    • 2001 Air Nautique
    I contacted Nautique and PCM about this when i bought my AIR. They said either straight 40 or 15w-40.
    Like most people I run 15w-40 Rotella (Shell)
    Current: 2001 Air Nautique GT-40
    • east tx skier
      • 1561
      • Tyler, TX
      I run 20W50 VR-1 which has over 1,200 ppm zddp.
      • jmo
        • Mar 2006
        • 710
        • MA
        Castrol GTX 15w-40 diesel, it also has the zddp additive the GT40 needs. I find the multi weight works better in Northern climates where you can have colder temps- especially in the Spring or Fall.
        2018 Ski Nautique 200 TE, H6
        • dsums
          • Nov 2006
          • 37
          • Vancouver, BC, Canada
          I contacted the local dealer recently and switched to Rotella T 15w40. It is a deisel oil that has the zinc phospate required fo rthe GT 40. I made the change after reading posts about excessive tappet and cam lobe wear if your oil doesn't have the necessary level of zddp.
          Hopefully there hasn't been any damage from running something else the previous 2 years
          • mcbridek
            • 241
            • Raleigh, NC, Lake Gaston NC
            • 06 Ski Nautique 196 SE (2010 - Current) 99 Sport Nautique / GT 40 / FCT (2005 - 2009)
            I always used 40wt, Valvoline VR1 Racing Oil, have always been able to get it at Carquest auto stores. A bit expensiive
            06 Ski Nautique 196 SE (2010)
            • mf01
              • Jun 2005
              • 515
              • Austin, TX
              I just picked up Valvoline VR1 20w50. I was using Rotella 15w40, but I was worried about the summer protection. Typically multiweights break down over time, so you're really using a mid 30 weight eventually.
              Previous:
              2011 Super Air Nautique 210
              1994 Sport Nautique
              • slob02
                • Sep 2003
                • 333
                40w
                2008 Super Air 210 Team
                2004 AIR 206 Team
                1997 Ski Nautique 196
                1993 Ski Nautique SNOB
                • acemech
                  • Aug 2006
                  • 35
                  • Ca.
                  • 1992 snob red/black
                  old thread but im curious here..ive had my 92 snob since 96. she has 600hrs on her, and i have always used castrol 40wt.Now this zddp stuff is for flat tappet engines?..
                  (im not into motors, so correct me here if im wrong).
                  Without me having to dig into it, i always thought the 92 351HO GT heads were equipped with rollers?
                  Eastwood has an zddp additive they sell for older cars....will this stuff work?
                  http://www.eastwood.com/zddp-plus-oi...e-4-fl-oz.html
                  thnks!
                  Ron
                  1992 SNOB GT40 sigpic- 96 engine cover with converted hull hugger exhaust.
