2001 Air Nautique 216 GT-40 Engine: Prop advice
  • m3the01
    • Aug 2004
    • 60
    Hey everyone,
    So finally we hit a rock and damaged the prop a little, can someone suggest a good replacement prop? We usually run a little wakeboarding with ballasts full and a fat sack in the front ski locker and slalom skiers.
    I actually dont know the exact prop i need so if you could help me out with that to it would be appreciated, money is extremely tight so a good used prop would be kool.
    Thanks so much for the help, are upgrade props any good? Suggestions welcome...
    Thanks again,
  • h2ohangtime
    • Aug 2009
    • 92
    • Frisco, TX
    • 2002 Super Air Nautique
    Used prop might be dangerous...it's hard to tell if there are small nicks in it that could cause vibration. I would call Acme or OJ and talk to their customer service...I've heard both are great and will recommend the right application for your boat and usage. Good luck...
    • jjgag60
      • Sep 2008
      • 165
      damged prop
      Did you consider fixing the old prop. To fix it cost around $100.00 give or take. They can do wonders with repairs.
      • 74green
        • Nov 2009
        • 281
        • Canyon Lake, Texas
        • 2001 Air Nautique
        Call Delta Prop. I use my boat for about the same as you mentioned and they told me to use the Acme 422. There is also a discount code when you purchase.
        Current: 2001 Air Nautique GT-40
