Easy way to syphon gas?
  • uwhusky
    • Aug 2006
    • 320
    • Salt Lake City
    • 2015 SANTE 210 w/PCM 450hp engine
    I have a 2007 SANTE 220 and wanted to take most of the gas out of it before I tow it about 400 miles on Friday. It currently has about 3/4 tank or 45 gallons, which I estimate weighs about 300 pounds.
    Is there an easy way to syphon the gas out other than snaking a garden hose down the fill tube? If not, I'll just tow it as is.
  • skijones
    • Mar 2005
    • 235
    • COLUMBUS OH
    • 1985 2001 1999 Snob
    I would tow as is. Level is low enough that you won't have to worry about spillage.
    Years ago, I tried to siphon gas out of my 85. Scraped bits of rubber off the hose and ended up clogging the pickup tube. Drove me nuts for months.
    • uwhusky
      • Aug 2006
      • 320
      • Salt Lake City
      Yeah, for 300 lbs lighter it's probably not worth syphoning unless it were super easy...like there was a drain plug under the boat or something, which I'm pretty sure there wouldn't be.
