I have a 2000 SN with a GT-40 engine. It looks like there is a crack in the starboard exhaust manifold which is causing a slight water leak (approx ten drips per minute). Is there anything I should be aware of before I replace the manifold? Would you replace both sides, even though the port side does not show any indications of wear or leaking?
Thanks!
Thanks!
