We have an 09 216V and have had the same issue three times now. The first two times it happened while maintaining 20+ mph for a few minutes and the last time it was while surfing, so speed can vary when the problem occurs. Basically going along like everything is perfect and all of the sudden the boat sputters and slows down to the 5 mph limp mode. If you give it more gas nothing, no speed and just a sputtering action. The first time they replaced the low pressure fuel pump and fuel/water separator. Second time filter and other fuel pump. This time, 15 hours worth of use since the last occurance, they can't get it to recreate the problem.
Any thoughts on what this could be? We're at the end of our patience level with it as it's a pain to get it off the water and back to the shop from our lake house every time. We bought a new boat so we would not experience these types of problems, but we're still having them. The last thing I want to do is pull it back to the lake house and have it happen again and have to tow it back to town. They took the fliter apart this time and there was nothing in it that was out of the ordinary. So we're all confused about the issue.
