air 206 cruise control
  • brad
    • Dec 2004
    • 33
    • Down Under
    i have a air 206 fitted with cruise control can anyone explain how it works
  • G-man
    • Jun 2004
    • 428
    • Allen, Texas
    Which cruise control do you have, Wakeboard Pro or Digital Pro? Basically you set a desired speed by RPM's or in MPH, take the boat up to that setting and it beeps and takes care of maintaining that setting until you pull the throttle back. I suggest you read the manual and get baseline settings calibrated on a slalom course or a gps. After you use it you'll wonder how you ever lived without it.
    Current
    2003 SkiNautique 206 LE Yellow - Black - Silver Cloud
    Previous Fleet
    2006 Ski Nautique 196 SE Titanium - Black- Silver Cloud
    2004 Ski Nautique 206 LE Red - Black - Silver Cloud
    1993 Mastercraft Stars & Stripes 190 Red
    • AbunDiga909
      • Sep 2003
      • 2470
      • St. Louis, MO
      Or, you could be talking about the standard cruise control, which I have never seen and is very unpopular. Do you know if you have Perfect Pass, (What george is talking about) or the small, unpopular, standard cruise control by CC.
      [color=blue][size=2][b]I Nautique, therefore I am.[/b][/size][/color]
      • brad
        • Dec 2004
        • 33
        • Down Under
        thanx but its the older standard cruise control by cc someone must know how it works
        • skinautique
          • 1749
          • Colorado
          http://www.perfectpass.com/pp_cruise.html
          • Edwin
            • 219
            • St. Louis
            read the manual? :?
            • Rick
              • Mar 2004
              • 1250
              • San Diego, Ca
              No No No have your wife read the manual and explain it to you. Men should never be made to read a manual...
              Nautiqueless in San Diego
              • G-man
                • Jun 2004
                • 428
                • Allen, Texas
                The old style cruise you turn it on in neutral gear take the boat to the desired speed, push the set button and it takes over. If the rider falls the next time up it will remember what was set before.
                Current
                Previous Fleet
                • brad
                  • Dec 2004
                  • 33
                  • Down Under
                  sweet that makes more sense but i think mine may be stuffed cause the motor seems chattery and does not want to hold the cable
                  • G-man
                    • Jun 2004
                    • 428
                    • Allen, Texas
                    I'm not sure what you mean by "stuffed" Who did the install? Perfect Pass has a low failure rate? I would have the installer look at it. Where are you located?
                    Current
                    Previous Fleet
                    • brad
                      • Dec 2004
                      • 33
                      • Down Under
                      its factory fitted....by stuffed i mean the motor seems to be jamming im going to take it out again 2day to see if it works better im in sydney australia
                      • G-man
                        • Jun 2004
                        • 428
                        • Allen, Texas
                        Brad just come over here to Texas and I'll show you how to operate it on my boat. Go to perfectpass.com and you can down load a manual. Good luck.
                        Current
                        Previous Fleet
                        • brad
                          • Dec 2004
                          • 33
                          • Down Under
                          yeah thanx george ill be right over.......i tried it again yesterday still no good i may even try to fit the new pp to my boat if this one doesnt work
                          • G-man
                            • Jun 2004
                            • 428
                            • Allen, Texas
                            Bummer Brad
                            If I don't show up this afternoon at your house the manual also has a trouble shooting section that may just help you out. You can call them but they are in eastern canada so the call may cost what the pp cost.
                            Current
                            Previous Fleet
                            • skinautique
                              • 1749
                              • Colorado
                              did no one see the link that I posted about how to use it?
