2009-2010 PME schematic
  • shag
    • 2217
    I had an issue not being able to find out where to hook my Underwater LED lights to, and the dealer furnished me this - from the factory. Yes it says 2010 - but I was informed it is the same layout. This is for the 230.
    Just thought others might be able to use this info.
    2010 230 PME pinout.pdf
  • shag
    • 2217
    Ok, now I need to figure out how to attach the LED wire into the PIN connector. Anyone? I am hesitant on d/c ing the connector.
    • Red57Bird
      • Aug 2007
      • 381
      • Raleigh, NC/Lake Gaston
      • 2003 Super Air
      I would use splice connectors. You can find them at most auto parts store. They are easy to use and work well.
      2003 SAN (current)
      2003 Chaparral 220 SSi (sold)
      • shag
        • 2217
        Hello Redbird,
        I can't use a splice connector here. There is actaully no wire coming from the pin connector. I have to take my lead wire, and somehow attach it to position 11 on the PME. I think I will have to take the connector off.
        • 210GA
          • Aug 2008
          • 282
          • Cartersville, Georgia
          • 2008 SANTE 210
          On mine I connected the under water lights to my courtesy lights in the rear of the boat with a splice connector.
          • shag
            • 2217
            I just found out that I need to get a type of connector that looks a little like an arrow - so I can push it in to the PIN connector, and it will stay.
            Also, on the 2009 and newer boats, they actually have a button on the keypad that is specifically for underwater lights. I believe it is the former "12 volt" button. The PIN schematic actually is actually labeled "transom lights".
