blew up the gear box i guess....
  • AZWAKEHOG
    • Jun 2010
    • 32
    • tucson az
    • 2003 AIR NAUTIQUE LIMITED TEAM EDITION
    is it cheaper to buy a whole new one or to rebuild it? also what would i look for as far as name or model # to replace it?
  • teamseal
    • Dec 2006
    • 395
    • Panama city, Florida.
    • 2009 196 ZR-6
    Gear box???? Need to be specific on what model boat you have and why you think it could be a "gear box" Failure.
    More info.
    • AZWAKEHOG
      • Jun 2010
      • 32
      • tucson az
      2003 air nautique limited it was making "ticking sound i took it into the shop and they said the gear box was low on oil so the put fluid in it and said they could charge me 100 to run it in the tank to see if the ticking would go away or i could take it out my self i did and on are third atempt to pull a skier it stoped movin with the throttle engaged it forward and reverse and now i think it destryoed the vdrive packin as well cuz it was leaking galons out when i put it on the trailer when normally it would only leak a little bit
      • AZWAKEHOG
        • Jun 2010
        • 32
        • tucson az
        sorry i forgot to put that it is a 226
