Touchpad Issues
+ More Options
Posts
  • zigs
    • May 2007
    • 98
    • ND
    • 2018 G21 2004 196
    Touchpad Issues
    I have an 01 Super Air that this weekend the touchpad starting acting up. When I got to the lake the battery was dead odd, but I have not used it for a couple weeks so no biggie, but after I got a charge on it I noticed the 12V button green light was on. So then I tried turning it off nothing, and couldn't turn on anything else, nav lights, ballast pump, bilge pump etc. So I took the 20 amp fuse out, and put it back in then 5 of the lights for the buttons were on and still could not use any of them. The keypad works fine so I put the boat in and used it all weekend and it never started working ever. Do you think its the touchpad? If not what else could be causing it? I took the dash off and double checked wiring and all the grounds on the battery, but I didn't have a multimeter with me so I couldn't get any voltage reading. Thanks for any and all help.
