Ballast Puppy for Starboard side quit working, checked breaker and swapped out, nothing. checked connector, nothing. then swapped contact to belly pump and it worked just fine (in reverse mind you).when I push the switch I can hear the relay kicking and the switch lights up. It will not discharge or fill the tank however......any suggestions before I take it to dealer??
