I keep getting a low oil pressure warning on the digital readout. The check engine light has come on and will not cut off, but it doesn't put me in limp mode. Pressure seems normal on on start up and running (between 37psi-65psi). It seems to jump around at idle and set the alarm off. Any ideas?
- May 2004
- 295
- Huntsville, AL
- 2008 Super Air Nautique 210 2003 Super Air Nautique Team 210 2001 Super Air Nautique Team 210 1999 Super Air Nautique 210 1994 Mastercraft Prostar 190 1992 Manta Ray 189 Sport
My 08 210 does the exact same thing. Initially, I thought I was going to have to clear the code in the computer to make the warning light go off. Then I talked with Tommy from White Lake. He said that the red light is probably due to a malfunctioning sensor. He said it is pretty common. I haven't done the troubleshooting on mine (disconnecting the sensor) yet due to just not having the time, but the oil pressure reading on the digital gauge is from a different sensor, and it should be accurate. If it is reading low oil and blinking red, you probably need to add some oil. I always carry some extra oil and a few towels and periodically check the oil the old fashioned way...
