351 HP
  • skier8100
    • Dec 2004
    • 3
    351 HP
    New to the site, hope someone can help me with a couple questions. Looking for the HP of a carbureted 351 HO? Engine was pulled from a 97 SN. I've seen it listed as 260 and 280. Which is it?
    Also, curious about the GT-40 heads. Worth it?
    Thanks.
  • M3Fan
    • 1034
    RE: 351 HP
    I think the HO had GT40 heads but was carb? Or was that the Pro Boss?
    2000 Ski Nautique GT-40
    2016 SN 200 H5
    www.Fifteenoff.com
    • darrel409
      • Jul 2004
      • 566
      • San Dimas, So. Cal
      RE: 351 HP
      I believe that the HO motor is 290 horse. Not sure if it has the GT-40 heads, that would make it a Pro Boss. Check your heads...GT-40 have 3 raised "notches" on the front. The standard heads are only 2 notch. Let us kno what you find.
      1995 Ski Nautique Pro Boss.
      • nms1991
        • 477
        RE: 351 HP
        Yes it is rated at 290 hp, and it does have the GT-40 heads but to be a Proboss it would have to have the Protec ignition system. The engine is equiped with a Prestolite distributor, the heads will also have GT cast into the head.
        • skier8100
          • Dec 2004
          • 3
          RE: 351 HP
          Thanks for the info. Turns out the heads are GT-40. Not sure on the ignition though--I'll have to check that out.
          • 502Python
            • Nov 2004
            • 74
            • IL
            RE: 351 HP
            I think you have 480 hp
            • 502Python
              • Nov 2004
              • 74
              • IL
              RE: 351 HP
              Sorry for this last post. After coming home from work in a bad mood and having a half bottle of Jack, it seemed funny at the time. Please disregard.
