Transmission issue
  • rshrews
    • 22
    Transmission issue
    Been a rough year on the ole 92.
    Had a buddy driving that was turing at just above idle speed to come scoop me up when he had to throw it in reverse pretty quickly to avoid a jetskier that wasn't paying attention.
    Anyways soon as he did it sounded like the prop came loose and was thudding very loudly when it was put in gear either forward or reverse. Sounds fine at idle and once we got a tow and out of the water the prop looked fine.
    Not sure what this means...assuming its a transmission issue.
    I don't have a nautique dealership within 100 miles so I have it at the MC dealership to have a look at it.
    Anyone else ever have this trouble and if so what was the outcome...
  • rickmustang
    • Aug 2008
    • 7
    Did you solve this issue
    I had an emergency stop today that sounds like yours. Was your transmission damaged? Rick
    • skijones
      • Mar 2005
      • 235
      • COLUMBUS OH
      • 1985 2001 1999 Snob
      Probably the damper plate, goes btw the flywheel and the trans input shaft. About $70+ for the part and about 2 hours of work.
