Hello all, been a while since my last post. I have a 2008 210 with I think the FCT II tower. The one with the thick tubing. It has a fairly bad shaking/swaying problem when in rough water or going over another boat wake. Does anyone know if this is a problem that is just inherent to that tower or do I have some other problem going on? Anyone know any solutions for this? Thanks.
Try this,
I have a 2006 with the same tower, the base plates have a large thread nut underneath up inside the coving behind the interior. Mine worked loose approx a 1/4 turn on each maybe a little more.
Use some thread lock on the threaded ends and tighten them up real tight, that should solve 90% of your shaking, particularly the front mounts. Also check the main black screw in tower nuts are tight.
Give it a try??
