Just bought the boat this year and now realize I have an oil leak. I appears to be the oil pan. I will be changing the oil pump and screen (just so I know its new), valve cover gaskets and oil pan gasket. The engine is a PCM 351.
My question is how hard is it to pull the motor. It doesn't look difficult at all but I didn't know if there were any secrets I needed to know about like out drive shaft to transom alignment or anything like that.
Any info is helpful.
