2001 Air questions, new owner
  • rickharp
    • Dec 2004
    • 70
    • Jupiter, FL
    • 2014 210 and 2013 200CB
    ON the dash pod, there are buttons to fill and drain the launch system, but the wires do not make it to the back. Under the dash, there are two bundles of wound up wires that when i check thier power, do not really come on with anything that i can tell. What is the procedure to get the power back to the ballast sytem if i was going to try to aftermarket somethin on my own.
    also, the keyless start seems to never reset and is always on or keyed. I've tried waiting for two days or more, i've tried entering the code to turn it off, etc, just wont become inop. could it be broke, or could the right primary or factory codes be used in some way to reset this. would a call to CC in orlando, John be helpful (when they get back from vacation).
    Thanks in advance
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    RE: 2001 Air questions, new owner
    SECC should also be able to help.
    Nautiqueless in San Diego
    • ssaxet
      • May 2004
      • 59
      • Lake Tapps, WA
      Check the wiring digram here on the site for a 2001 pro air, Im guessing its very similar if not exact to the air.
      I think all all the pad buttons go to the realy box mounted on the kick pnl and power the accy from the relay... look for the wire colors in the realy box harness...not at the pad...
      2001 PAN 1995 ramlin single axle
