95 sport gt-40 Vapor lock
  • dmbump
    • Jun 2010
    • 7
    • 95 sport gt-40
    Changed fuel pumps and still have vapor lock. Engine starts when cold and will restart with in first 10 min and then nothing until it cools off. Any thoughts?
  • Ceruzziracing
    • Jul 2010
    • 58
    • Lenexa, Kansas
    • 1997 Ski Nautique 176 GT40
    I think I read recently here on the forums that there is a ball/check valve in the vent system that can get sticky. IIRC, someone here just posted up a similar prob and the cause was an $11 check valve...
    '97 SN 176 GT40
    • td95sport
      • Apr 2007
      • 54
      • King, NC
      I have a 95 Sport and have been having some issues that make me think it is vapor lock. I replaced the low pressure fuel pump and that was not the problem. Then replaced the high pressure fuel pump which helped out the problem. It still has problems every once in a while, not as bad as it was. I have found if it doesn't want to start I cycle the key on and off about five or six times to build fuel pressure it will start. Maybe I haven't found all of my problem is why i have to cycle it. I have been told that 95 was the only year they used our style fuel system then switched to the FCC system. I think they make a conversion to the FCC system that will help with the vapor lock problem. I hope this helps!
      • tom dixon
        • Aug 2010
        • 2
        • 1997 sport nautique
        had exact prob on my 98 after replacing both pumps and spending countless hours found there is a tiny pickup screen in bottom of fuel tank pu hose removed never a problem again nobody seems to know it is there
        • bwana50
          • Jan 2008
          • 69
          • Topeka, KS
          Which pump did you replace? Replacing the LP pump solved my similar problems.
          1996 Ski Nautique
          • tom dixon
            • Aug 2010
            • 2
            replaced lp pump first thought i fixed problem second time out re occured if pumps get starved for fuel they will burn up then replaced hp pump and found screen after removing complete fuelsystem hoses tank etc twice never ran better
            • lakept
              • Jun 2010
              • 8
              • 1995 Ski Nautique, GT40
              I had similar problem and just replaced the low pressure fuel pump and it is much better. It will sometimes not start when hot on the first try but always by the third attempt.
              I am curious as to where the fuel screens are located? I believe there is one in the bottom pickup hose of the tank and then again somewhere either before, between, or after the two fuel pumps.
