Winterizing Details
  • wakeany1
    • May 2010
    • 64
    • Canada
    • 2017 G21 Team H6 2014 Super Air 210 Team 1996 Ski Nauitique 2003 Super
    Winterizing Details
    Does anyone have a detailed winterizing procedure to follow other than the basic one in the manual......Engine Block, Heaters, Ballast Tanks for up to 35C degrees For a 2003 210???? Or a website That is very detailed?????
  • wake4life6
    • Mar 2009
    • 218
    • Olympia, Washington
    yea keep using your boat till it gets cold and dont mention this again till the season is over
    2006 210 SAN! TE
    • wakeany1
      • May 2010
      • 64
      • Canada
      That's very funny
      • HS
        • Oct 2007
        • 1333
        • Sammamish, WA
        • 2010 SANTE 210 (Sold)
        details
        http://www.planetnautique.com/vb3/sh...res-GM-Engines
        • wakeany1
          • May 2010
          • 64
          • Canada
          Thankyou very much very handy!!!
          • ejnautique
            • Sep 2010
            • 7
            • Michigan
            • 2002 Super Air Nautique Team Edition
            Anything for Ford GT40 PCM SAN?
            • jjgag60
              • Sep 2008
              • 165
              Winterization Gt-40
              Here is my list for Winterization for the Gt-40
              Gt-40 Winterization
              1. Change oil, transmission, v-drive: run motor with new oil to pressurize filter
              2. Blue Stabil in gas
              3. Open ballast valves, blow out water
              4. Fog cylinders- individual holes, not through throttle body
              5. Remove heater hose at sensor blow water out
              6. Remove heater hose starboard side of block
              7. Remove plug on transmission cooler
              8. Remove shower hose (red) from block
              9. Remove plug from bottom of “U” housing
              10. Remove impeller
              11. Empty strainer
              12. Drain V-drive
              13. Place grease in steering boot
              14. Cover exhaust port with 4 inch plumbers cover
              15. Blow out heater
              16. Run shower pump to empty
              17. Remove Battery.
              18. Drain the water out of manifolds
              • Shooter
                • Feb 2025
                • 264
                • Orange County California
                • 2003 SANTE 210
                Parts
                16 OZ Sta-bil $7
                4 QT Rotella 15W-40 Oil $27
                1 Napa Gold 1515 Oil Filter $5
                * 2 QT Dextron III (DEX/MERC) Trans Fluid $8
                * 1 Impeller (Skidim Part # 0713) $36
                * 1 Fuel Filter (Skidim Part # 0511) $36
                Yearly Winterization / Maintance
                1 Add Sta-bil (16 oz) & fill gas tank
                2 * Replace fuel / water filter / separator
                3 Hook up fake-a-lake, run up to operating temp & disconnect
                4 Change engine oil & filter
                5 * Change tranny fluid
                6 Remove / clean raw water strainer basket (Dont loose the O-ring)
                7 Drain block- Remove plugs each side (Sensor on port side)
                Drain manifolds- Remove plugs each side
                Drain engine / trans cooler- Remove plug
                8 Remove hoses from the inlet side of water pump and engine circulating pump
                9 Remove heater hoses and blow water out both ways with low PSI
                10 Reinstall all drain plugs and hoses
                11 Tighten all hose clamps with 5/16" nut driver
                12 Check V-belts (*loosen the alternator and water pump belts)
                13 Lubricate throttle and transmission cables w/ fogging oil
                14 Remove spark plugs & spray fogging oil in the cylinders. Re-install spark plugs, remove the
                coil wire and turn engine over a couple rotations.
                15 * Change or check impeller
                16 Hook up battery charger
                17 * Remove prop for service
                18 * Grease or re-pack trailer wheel hubs
                19 Clean boat & remove cushions to allow airflow.
                20 Clean & oil swim step
                21 Place tape over exhaust ports and scuppers to keep insects out.
                *= Service done every two years or as needed
                • Shooter
                  • Feb 2025
                  • 264
                  • 2003 SANTE 210
                  The above is my list for the Excalibur 330 without closed cooling and heater.
                  I don’t have freezing issues where I live so I may not drain the water #7-#10...Should I do it anyway?
                  I don’t think I will fog the cylinders #14 because I have heard conflicting suggestions.
                  • johnboyy7
                    • Oct 2009
                    • 409
                    • houston
                    How do I lube the throttle and trans cables?
                    04 SANTE 210
                    89 SPORT
                    • gride
                      • Jun 2007
                      • 1441
                      • War Eagle
                      • 05' 210 team
                      some 30/30 lube on the linkage. pics in the manuals on homepage.
                      • johnboyy7
                        • Oct 2009
                        • 409
                        • houston
                        04 SANTE 210
                        89 SPORT
                        • johnboyy7
                          • Oct 2009
                          • 409
                          • houston
                          Can you direct me I'm having trouble finding it. Thanks
                          04 SANTE 210
                          89 SPORT
                          • gmdattilo
                            • Apr 2010
                            • 30
                            • Louisville KY
                            • 2000 A-N
                            Pulling the Raw Water Impeller
                            How do you guys pull your old raw water impellers out of the pump housing?
                            I have seen pullers advertised but they need 5 inches of clearance, my ski pylon is in the way.
                            Please advise.
                            • jmo
                              • Mar 2006
                              • 707
                              • MA
                              Please advise.
                              Puller for the impeller? What engine do you have? On my gt40 I just unbolt the RWP from the block and then open it up to access the impeller, from there I just spin it out by hand. Before you disconnect the RWP make sure you mark which end connects to each hose as once it's off it easy to get confused as to how it goes back together.
                              Hope this helps.
                              2018 Ski Nautique 200 TE, H6
