2000 Air with GT-40 won't start
  • wcherashore
    • Sep 2009
    • 190
    • San Diego, CA
    I have been out of town for two weeks and took my boat out for the first time yesterday. I could not get the boat to start. It would start and turn over, but immediately cut out as if the boat's lanyard was not in place or the boat was in gear. I had had this happen before due to a connection with the lanyard, so the first thing I did was check the lanyard connection and make sure the boat was in neutral after a few tries. Afterwards, the boat would not longer turn over. Having been out of town my next thought was that the battery was low and it was in fact a little under 12v which is about normal on my boat. I pulled it out of the water and jumped it and restored the battery back to a normal level (slightly higher). After trying it again, I had the same result.
    Any suggestions? I can't imagine it is a big issue as the boat was recently in for its annual service. Any help would be much appreciated because I'd like to use it this weekend.
  • nautiquesonly
    • May 2004
    • 60
    • 1972 Mustang 1980 Ski Nautique 1998 Sport Nautique
    2000 Air wont start
    If this is EFI then I would check the fuel pump relay as this is a common problem. If you turn the key on and dont hear the fuel pump come on then that would be a indication it is bad.
    sigpic Masters Edition 98 Sport Nautique/GT40 Acme 422
    • drobshaw
      • Aug 2010
      • 12
      • 2003 super air nautique(gt40) 2001 super air nautique(gt 40)
      2001 SAN, w/same issue
      I unplugged the coil wire from the distributer cap and the coil, wire brushed both terminals and cleaned with light sandpaper (was black with corrosion) , and it worked fine, it was a free fix, and you can't beat that, hope it works for you
      • east tx skier
        • 1561
        • Tyler, TX
        Check the wiring on the back of the ignition (key). I had one come loose once and caused a symptom similar to a loose safety lanyard.
        • wcherashore
          • Sep 2009
          • 190
          • San Diego, CA
          the kill switch was faulty and not closing the circuit... thanks
