I have a 2000 Air with bags plummed into the rear compartment and the ski locker (in addition to the sock tanks in the rear). I am adding a vent to the rear sac th is tee'd into the stock tank vent after the check-valve.
However, I can not find a good way to run the vent line from the sack in the ski locker.
Everything around the ski locker seems to be "sealed" off. No visible way to run a line sideways/under the floor. The drain for the glove box goes down into the floor, but I am not sure where it heads - there is no thru-hull out the side, so my guess is into the bilge. I would like to run the vent under the driver to the stock vent thru-hull for the rear tanks, but I can not see anywhere I can run the line. Any suggestions? Am I going to have to cut a hole in the floor near/under the stereo (behind the bezel)?
The only clean option I see is to run the line back to the rear of the boat and maybe vent it out with the rear tanks, but it seems like there must be something easier.
Any ideas?
Any ideas?
