GT 40 Spark plugs with oil - What to do?
  • rappleby99
    • Sep 2009
    • 6
    • Panama
    • 1995 Super Sport Nautique
    Hi there. Recently did the spark plugs change, and found out that two of them had oil on them.
    What should I do, and what causes this problem.
    So far, the boat is running well, did not noticed any difference.
    Thanks for any advice.
  • jjgag60
    • Sep 2008
    • 165
    gt-40
    Is your motor fuel injected? if so you may have a bad injector that is pumping to much gas. Do a compression check on the motor and see if there is a significant difference between the cyclinders. How many hours are on the motor?
    • rappleby99
      • Sep 2009
      • 6
      • Panama
      Thanks, yes it is fuel injected. I'll try to do the compression test.
      Engine has about 430hrs
      • jedgell
        • 170
        • Bozeman, MT
        • 2004 SN 196
        My '95 has always had one plug with oil on it. It's the aft most plug on the starboard (driver's) side. I've heard that it's from the angle the engine sits at and the oil seeps into the cylinder when not being used. No idea if this is accurate or not, but there's been oil on that plug since I bought it at 130 hrs, and now has over 515 with no issues.
        \'95 SN Signature Ed.
        GT-40
        PP Stargaze
        **For Sale**
        • horkn
          • Aug 2007
          • 270
          • WI
          Check the oil level first.
          It may be too high, either from overfilling, or from gas or water in the pan.
          • rappleby99
            • Sep 2009
            • 6
            • Panama
            Well, in my case, the engine is consuming a little amount of oil, less than half qt every oil change (50 hrs).
            It runs fine, nothing is wrong, but don't think this is normal.
