2003 SANTE with engine surging issues.
  • Bimmerboyz
    • Feb 2009
    • 378
    • Herriman UT
    • 1978 Ski Nautique that I miss:-( 2003 SANTE
    I took my boat out and made a hard left turn and the boat felt like it cut out. I proceeded with my day and did not notice it again, until I was pulling a tube 5 hours later. It felt like the prop is getting held up. Pulled the boat out and noticed my prop is bent.
    Would a bent prop cause the boat to surge? Does the computer cut fuel if it feels unbalanced?
    I planned on upgrading my prop anyway but can this be fixed so I have a spare?
  • Bimmerboyz
    • Feb 2009
    • 378
    • Herriman UT
    Another question where should I buy a prop? What dealer. The 1464 is what I have been told is the best upgrade for my boat.
    • gride300
      • Apr 2008
      • 1356
      • mobile, al
      you can get that one fixed, but buy a new one from deltaprop and get the discount. and then you'll have a spare.
      • Bimmerboyz
        • Feb 2009
        • 378
        • Herriman UT
        So is the prop my issue with surging?
        Is this the prop I want?
        http://www.deltaprop.com/shopaddtocart.asp
        • bowvan
          • Aug 2005
          • 100
          • sacramento
          A bent prop is more prone to cavitation. It sounds like that is what your experiencing when you turned. In addition to the power loss, you should have felt a considerable amount of vibration and noise. It should have all gone away when you straightened out and reduce the RPM's.
