engine temp question
  • rabbit
    • Mar 2010
    • 37
    My impeller went out last week, changed it out and on the fake lake the temp got to about 160 then dropped to about 120. On the river, it was running about 111 degrees...is this correct? seems really low temp.
    Thanks,
    Ben
  • mf01
    • Jun 2005
    • 515
    • Austin, TX
    Sounds like the thermostat is getting stuck open. Did the impeller disintegrate? Maybe some of the rubber is stuck in the thermostat.
    Previous:
    2011 Super Air Nautique 210
    1994 Sport Nautique
    • rabbit
      • Mar 2010
      • 37
      half of it was torn up...i should check the thermostat.
      • Nautiques in ME
        • Jul 2010
        • 4
        • Gorham Maine
        • 2004 Mastercraft 197 Sammy Duval Edition
        I would blow out the lines too just to makes sure that there are no extra pieces ready to ruin your day.
        • drobshaw
          • Aug 2010
          • 12
          • 2003 super air nautique(gt40) 2001 super air nautique(gt 40)
          had same issue
          with my 2001 SAN with the GT 40, was overheating, changed impeller, was half gone, was still overheating so I changed the thermostat, and now it stays at 160 always, goes to around 190 if i leave it to idle to long with no movement, but who wants to waste gas at these prices!!
          • drobshaw
            • Aug 2010
            • 12
            replacing thermostat
            replacing the thermostat itself is inexpensive ($15-$20) for the part, $100 for labor at at dealer, but you can do it yourself. only 2 bolts, it's just a B to get them out
            • WakeSlayer
              • Sep 2005
              • 2069
              • Silver Creek, MN
              • 1968 Mustang
              ???. I don't get it. It should not really go above 160*. If you are hitting 190* at idle, you have an air leak. Tighten your hose clamps with a 5/16 nut driver. At least annually.
              the WakeSlayer
              1968 Correct Craft Mustang
              • drobshaw
                • Aug 2010
                • 12
                I had a mechanic tell me that i need to close the valve on the fake a lake, when i run it in the driveway i tend to just cap the hose and not close the valve. i'll see what happens
