All with Jabsco Ballast Puppy and Fat Sacs
  • intrlaz
    • Aug 2009
    • 230
    Did you guys place your rear sacs with the hose connection at the back or front of the locker? Obviously with my aerator pumps, the drain hose connection was at the back of the locker.
    Now that I'm upgrading to reversibles, can I flip the sacs around and save myself some time and $ running hoses to the rear? Wondering if they will drain all the way if I do this.
  • steve-o
    • Jul 2009
    • 231
    Mine are in the front.
    • intrlaz
      • Aug 2009
      • 230
      Thanks Steve-o
      • seth
        • Jun 2008
        • 549
        • Santa Barbara, CA
        • 01 SAN-sold
        mine are at the front to and drain all the water.
        • ers906
          • Feb 2010
          • 921
          • Phoenix AZ
          I imagine that you can. Otherwise you can build a slight ramp forcing the water towards the fill/empty line
          Eric, Phoenix AZ
          G23 550 hp (finally here)
          2002 Super Air
          • wake_fun
            • 1330
            • CA
            • 1995 Super Sport
            Front top to fill/empty........rear top for vent.
            Photo Album
            Ballast Install 1
            Ballast Install 2
            Amp Install
            PPass Install
            Alternator Install
            • intrlaz
              • Aug 2009
              • 230
              Wake fun- how are you emptying from the top?????
              • ers906
                • Feb 2010
                • 921
                • Phoenix AZ
                I think you can if there is a one-way check valve on your vent line. i have heard of people doing it htis way, but I havent myself. I actually put my fill/empty as far back towards the transom as possible.
                Eric, Phoenix AZ
                2002 Super Air
                • RainDog
                  • Jan 2008
                  • 64
                  • Wauwatosa/Green Lake WI
                  • 1962 Classic 2002 SAN -Python Powered-
                  Front bottom - fill and drain, top rear - vent.
                  1962 Classic
                  2002 Super Air -Python Powered-
                  Many more to come....
                  • ers906
                    • Feb 2010
                    • 921
                    • Phoenix AZ
                    Any new projects Raindog?
                    Eric, Phoenix AZ
                    2002 Super Air
                    • RainDog
                      • Jan 2008
                      • 64
                      No, I'm still tweaking from this spring. Due to work and family obligations, I won't hit the lake house until Labor Day weekend. Still working to get the best surf combo, hopefully I'll have that sorted out then.
                      1962 Classic
                      • wake_fun
                        • 1330
                        • CA
                        • 1995 Super Sport
                        Because there is ZERO air in the system. My bags fill and vent out the side, pushing all air out of the system. It sucks the bags down to raisins when I reverse my pumps because the check valve doesn't let air back in I have two batteries in front of my bags and didn't want to use the bottom inlet. It works perfect!
                        Photo Album
                        Ballast Install 1
                        Ballast Install 2
                        Amp Install
                        PPass Install
                        Alternator Install
                        • ers906
                          • Feb 2010
                          • 921
                          • Phoenix AZ
                          Wake fun
                          I read your ballast set up install post when I was designing my set up. It is all installed, works great, etc. The one thing I would change is add in the check valves so the bags drain completely. A couple of questions
                          1) What size hosing did you use for your vent lines
                          2) For the check valves did you use the outer diameter or inner diameter style?
                          Thanks
                          Eric
                          Eric, Phoenix AZ
                          2002 Super Air
                          • wake_fun
                            • 1330
                            • CA
                            • 1995 Super Sport
                            Originally posted by ers906 View Post
                            Wake fun
                            Thanks
                            Eric
                            Look at my ballast install part 2.......I added the check valves a long time ago
                            1) 1" hose for everything
                            2) In my ballast install part 2 I listed the valve I used and where I bought them. I don't know what you mean by inner or outer I think these are them: http://www.boatersworld.com/product/MP80821176.htm
                            Photo Album
                            Ballast Install 1
                            Ballast Install 2
                            Amp Install
                            PPass Install
                            Alternator Install
                            • ers906
                              • Feb 2010
                              • 921
                              • Phoenix AZ
                              Sorry, I meant that did the check valves go around the outer diameter of the vent tube, or do they slip into the internal diameter of the tube.
                              Eric, Phoenix AZ
                              2002 Super Air
