03 San perfect pass adjustment when weighted?
  • hype1108
    • Jul 2010
    • 13
    • 2003 210 Team Edition Nautique
    When I load my 03 San up with about 3000 pounds of weight, the perfect pass is not as responsive but I heard it can be adjusted. Can you tell me how to adjust perfect pass so I can get it sorted. Thank you!
  • nsteffens
    • Jul 2009
    • 55
    Here is what I found out to work the best.
    If the boat is taking too long to adjust and goes way beyond the setpoint, lower the NN. Keep lowering the NN value until you feel the boat constanly adjusting the throtle and it will only sway by .2 - .4
    I belive the KDW is set to 120 from the factory. This is how much throttle is sent to the engine when an adjustment is needed. You may need to adjust this to a higher value after you've dialed in the NN because of the increase in weight.
    Each setting is unique to rider, boat, response, weight, etc so whatever someone says is there value may not work in your case.
    You can get the directions to modify those settings from Perfect Pass site.
    • gride300
      • Apr 2008
      • 1356
      • mobile, al
      with the perfect pass off press the menu and on/off buttons together to bring up settings. i like to have the nn around 83 and the kdw around 95. you just have to play with it. i constantly change mine since i'll go a while w/o any weight and then load it down heavy for a while.
