Underneath my 2009 211 are a set of brass water intakes/drains. Three are round and flush mounted to the hull, and two are "hooded" or raised. I assume (but don't know for sure) that the raised intakes are for the cooling system (why two?), and the flush intakes are for the ballast tanks. Is that correct?
Is it also true that the flush mounted intakes serve as both intakes and drains for the ballast tanks, depending on which direction the pump is running?
Finally, is there a way to know which intake fills which tank? Thanks.
