Muffler replacement
  • pj
    • Oct 2003
    • 323
    • Rochester, MN
    • 1991 SN 1996 SN
    Muffler replacement
    i've got a '91 SN with the invertaflow system on it. the starboard side connection from the exhaust manifold is in pretty bad shape and is currently being held together by (mostly) RTV sealant. i've heard some pretty nasty stories about what can happen when the invertaflow muffler blows out. has anybody replaced these? what kind of setup should i be looking for?
    Thanks.
    Once you have tasted flight, you will forever walk the earth with your eyes turned skyward. For it is there you have been and there you will long to return. - Leonardo De Vinci
  • skijones
    • Mar 2005
    • 235
    • COLUMBUS OH
    • 1985 2001 1999 Snob
    Repair what you have. It's a good place to practice glass work. Nobody will ever see it.
    After you get done, figure out a way to pressure test it, it is below the waterline and if it leaks, not pretty.
    • areford
      • Aug 2009
      • 34
      • Fayetteville, GA
      • 1993 Sport Nautique
      Muffler replacement
      Yeah fix what ya got. I repaired mine this winter and it has worked well. If u can, make sure to get some epoxy on the inside as well if there are any cracks or holes.
      1993 Sport Nautique
      - New Interior - Copycat Covers
      - Ramlin Trailer overhaul
      - Buff and polish oxidated gel coat
      - Exhaust repair
      - Holley rebuild
      Previous: 1980 Mastercraft - Lake Lanier. GA
