water will not circulate through the engine
  • prsgtrman
    • Feb 2007
    • 6
    i drained my block a couple weeks ago because i thought i was not going to be able to use the boat for the remainder of the year. long story short i tried to take it out the other day and it over heated. the impeller was shot so i replaced that and removed all the veins i could find. now i cannot get water to circulate through the engine(i emptied the strainer and it wont fill up when i attach a water source i.e. hose). im certain the problem was there before the impeller blew and the lack of water circulation was what caused the impeller to fail. anyone have any idea what im issue is? the water pump seems fine. no play in the pulley.
  • prsgtrman
    • Feb 2007
    • 6
    the boat is an 02 san 5.7 350 pcm excalibur
    • slob02
      • Sep 2003
      • 333
      Make sure the hose is clean from the strainer to the intake at the bottom of the boat. Make sure the black "O" ring is on the strainer and if you have a water shut off at the intake, make sure it is open. Some places to start.
      2008 Super Air 210 Team
      2004 AIR 206 Team
      1997 Ski Nautique 196
      1993 Ski Nautique SNOB
