2000 SAN hydraulic door lift problems
  • drdon
    • Sep 2010
    • 3
    • 2000 SAN
    Hi,
    I'm new to this forum and would appreciate hints on how to service my 2000 SAN hydraulic locker door. It was working fine last time out, but now the door won't open. When I push the button to open it, it makes a clicking noise. Is this something I can fix for do I have to buy a new hydraulic pump or piston?
    Thanks,
    Don
  • Boardboy
    • May 2009
    • 39
    2000 Hydraulic Door
    Check inline fuse just before battery. Also follow hydraulic motor power lead to relay and try replacing relay.
    • drdon
      • Sep 2010
      • 3
      • 2000 SAN
      Thanks, I'll give that a try.
      Don
      • ers906
        • Feb 2010
        • 921
        • Phoenix AZ
        I have also had problems with the screws slightly coming out which jams the mechanism. Can you manually open the door?
        Eric, Phoenix AZ
        G23 550 hp (finally here)
        2002 Super Air
        • drdon
          • Sep 2010
          • 3
          • 2000 SAN
          I haven't tried opening the door yet. I plan to drive up to the lake where the boat is and work on it this weekend. If I can't open the door, I will take out the back seat and pop the pin out of the hinge to open it up. I'll check the screws, fuse and relay. Thanks for the tips and I'll let you all know how it goes.
          • WakeSlayer
            • Sep 2005
            • 2069
            • Silver Creek, MN
            • 1968 Mustang
            If your actuator ever does give out, try here. They are about an eighth the cost of a Nautique replacement.
            http://www.dcactuators.com/
            the WakeSlayer
            1968 Correct Craft Mustang
            • horkn
              • Aug 2007
              • 270
              • WI
              Yep, I personally have seen this happen too on a 2000. If it won't manually open, you will have to spend a bit of time with some small tools to try and get the mechanism to allow the hatch to open. Once it is open, then tighten the mechanism down.
              The boat it happened on was not my boat, and as such the owner said it simply made the jingly noise back there ad it wouldn't affect anything. That was fine and only annoying until the mechanism backed off so much that the latch would not unlatch and we needed to get stuff out of the locker. I got it, with improvised tools on shore, but it was a PITA.
              Bottom line, if the latch is loose, don't deal with the noise thinking it does not affect anything. Tighten it down while you can still open the hatch. It will back off and not open, affecting people then.
