12 volt outlet broken
  • hondaprlud
    • Jul 2008
    • 568
    • OH-IO
    Tuesday I plugged in to the 12 volt outlet and it wasn't working, I thought it was the pump that I was using so I didn't worry too much about it and we stayed on the water. Well it's not the pump. I see in the manual it says thee is a 10 amp breaker for these, where is it located? Is there anything else that breaks/corrodes that I should look for?
    19 SANTE 210
    08 SANTE 210 ZR6
    08 SANTE 230 ZR6
    88 Baja Ski Sport- First boat
  • ers906
    • Feb 2010
    • 921
    • Phoenix AZ
    In my boat the breakers are labeled on the kick panel on the drivers side feet. I would check that first. Afterwards, I would pull the outlet itself and look at the connections. Use a voltage tester and see if you are getting power to the outlet if the breaker is good.
    Eric, Phoenix AZ
    G23 550 hp (finally here)
    2002 Super Air
    • HS
      • Oct 2007
      • 1333
      • Sammamish, WA
      • 2010 SANTE 210 (Sold)
      Outlet
      Could be the breaker, but just in case, there is a 12v button on the dash pod that is supposed to send power to the outlet (based on my reading of the owners manual) but in my experience, the button does not have to be pressed for the outlet to be hot -- but it could be worth checking.
      • ers906
        • Feb 2010
        • 921
        • Phoenix AZ
        I never understood what that button was for. I have never pressed it and I have always hat "hot" outlets.
        Eric, Phoenix AZ
        2002 Super Air
        • h2ohangtime
          • Aug 2009
          • 92
          • Frisco, TX
          • 2002 Super Air Nautique
          My 12v button is for the docking lights on my 2002 SAN.
          • ers906
            • Feb 2010
            • 921
            • Phoenix AZ
            I think that it is an on-off switch that can be used for any 12V accessory
            Eric, Phoenix AZ
            2002 Super Air
            • j2nh
              • Dec 2003
              • 628
              • Spread Eagle Wisconsin
              Check the wiring to the outlet. When mine came it was hooked up backward. Possible a wire has come off. Multi tester and you will have it going in 10 minutes.
              2018 200 Team H6
              2009 196 Team ZR 409
              2005 196 Limited ZR 375
              2003 196 Limited Excalibur
              1999 196 Masters Edition
              1987 ProStar 190
              • hondaprlud
                • Jul 2008
                • 568
                • OH-IO
                Thanks guys, I had quickly checked the fuses on the kick panel, I'd assumed these are more breakers and not fuses and when they pop they stick out. none of them were sticking out. but I wasn't super thorough because I really thought the pump had died. So I'll double check them. 12V button on the dash? I've never noticed it, but I'll check that too. It was really strange because I'd used that outlet earlier in the day, that's why I really thought the 15 year old air pump was the culprit not the outlet itself.
                My wife has Labor day plans that doesn't involve boats, so I'll probably won't get back out to it until next week.
                Thanks for the advise so far.
                19 SANTE 210
                08 SANTE 210 ZR6
                08 SANTE 230 ZR6
                • Chexi
                  • Feb 2025
                  • 2119
                  • Austin
                  • 2000 SAN
                  My 12v breaker/button on my dash definitely turns on and off the 12v dash plug.
                  Now
                  2000 SAN
                  Previously
                  1999 Air Nautique
                  1996 Tige Pre-2000
                  • hondaprlud
                    • Jul 2008
                    • 568
                    • OH-IO
                    Made it back on the water last night. I was just the breaker by the kick panel. interestingly I dont have a 12 volt button on the dash pod.
                    Thanks for the help!
                    19 SANTE 210
                    08 SANTE 210 ZR6
                    08 SANTE 230 ZR6
