Mount your jabsco ballast puppies so leaks can't flood them. A single outing blew mine. Pics to come
Did you have yours laying flat or something?
I have 3 pumps mounted behind the rear bench seat. I had to mount one of them where the hose fittings were above the motor housing.
Unfortunately I did not realize that the hard ballast hose you get from wakemakers must be clamped down much harder than regular heater hose to keep from leaking. Didn't help that we were in brackish water either.
My guess is the water leaked through the vents in the impeller housing and just sat at the bottom of the motor for the entire week until we went out again.
I emailed jabsco to see if I could buy a replacement motor only. I will let you all know what they say
Yeah, that sucks!
I can see how using that hard hose would do that. I used a softer hose on my build and it's been perfect for all these years. I would spray some throttle body cleaner or carb cleaner in there and clean it all out. It might work!?
- Feb 2010
- 921
- Phoenix AZ
- 2013 G23 550 hp (ordered and awaiting delivery) 2002 Super Sport (coverted into a SAN) 330 hp Excaliber 1994 Sun Tracker Party Barge 115 hp 1989 Horizon 200 Four Winns - sold 1989 Regal Commodore 280 - previous Possibly looking into picking up a 70'2-80's Nautique to rebuild as a ski boat
Did that happen all of ur pumps or just the one? That hose was such a bitch to get on I can imagine it leaking. Still ended up putting on two hose clamps for good measureEric, Phoenix AZ
G23 550 hp (finally here)
2002 Super Air
Originally posted by intrlaz View PostSo I found out that you can only buy Jabsco parts from authorized distributors (not resellers), one of which is West Marine. They quoted me 250+ for the motor alone. Not surprisingNow
2000 SAN
Previously
1999 Air Nautique
1996 Tige Pre-2000
