Pulling a wake boarder yesterday, new battery with full charge, boat lost all power and had to be towed. Checked kill switch and breakers, battery still has charge.
When you say lost all power, do you mean that the electicity went out completely, or do you mean that the boat was still running but would not go above idle. If the boat was still running but only at idle, the computer is putting you into limp home mode.
BKH2001 Super Air
Lost power
Did you happen to check the safety lanyard? Could have accidently knocked off or partially off enough to kill power. Would it stiull crank? If not, I agree with cleaning/checking and tightening the battery terminals.2004 196 LE Black/Grey
330HP Excalibur Water Churner
2002 Grey F150 Harley
475+HP Supercharged Tire Burner
