Sherwood water pump
  • go46
    • Aug 2003
    • 44
    Sherwood water pump
    I just changed the impeller on the 97 ski and wanted to double check that I put the pump back on correctly. The cam screw faces in towards the engine right? I am 99% sure it does.
    thanks
  • skinautique
    • 1749
    • Colorado
    Two ways to find this out. One: if you look at the housing, one side is painted and the other isn't. The painted side should be on the outside. Also, if you fire it up and it isn't pumping water, you probably have it on backwards. Sorry I don't remember the screw location off hand. Your dealer could quickly verify it for you though.
    • M3Fan
      • 1034
      Find a picture online on ebay or something that shows the front of someone's engine and look at that. I don't have a pic on hand or I'd just post it.
      2000 Ski Nautique GT-40
      2016 SN 200 H5
      www.Fifteenoff.com
      • go46
        • Aug 2003
        • 44
        Screw goes on the inside.
