water in oil
  • laurie88
    • Mar 2010
    • 75
    • model 206
    water in oil
    no power loss or overheat or drop in oil pressur but water on tips of 3 plugs and oil is brown and level way above full on dipstick, could it be cracked manifold or burst oil seale any thoughts................400 hrs compression test fine
  • nms1991
    • 477
    Are the spark plugs getting wet on one side only, or are they on different sides of the engine? If they are on one side only check your exhaust manifold for a internal leak or bad riser gasket.
    • laurie88
      • Mar 2010
      • 75
      • model 206
      water in oil
      just wet on one side 3 plugs, maybe this could be exhaust manifold
