misfire pcm excalabur 330hp... 400hrs
  • laurie88
    • Mar 2010
    • 75
    • model 206
    changed plugs, fuel filters, fuel pumps, no o/heat , no prob starting, good fuel pressure 60psi, changed gas, checked resistance on leads all same,good comprression but under load at just 1500rpm everytime starts misfire bad,
    changed exhaiust maniflold just before this misfire issue, could it be related to exhaust any ideas anybody thanks
  • thedude
    • Apr 2007
    • 451
    • SW PA
    What about the distributor cap and rotor? Are you certain no plug wires are crossed?
    • causewayskiier
      • Mar 2006
      • 101
      missfire
      I had the same problem with my '07 with 330 HP. I finally changed the rotor cap and that seems to have solved the problem.
      • georges
        • Apr 2008
        • 32
        • Franklin, TN
        • 2007 211 Team 1991 Sport
        missfire
        I had he same problem on a '07 211. After changing plugs, wires, etc. the dealer used his computer with a lake test. The timing was off at slow speeds. He made an adjustment which corrected the problem. Good Luck!
        • causewayskiier
          • Mar 2006
          • 101
          missfire
          • laurie88
            • Mar 2010
            • 75
            • model 206
            missfire
            thanks guys
            i have some questions
            i thought the timing was fixed and non adjustable?? i do not have delaer here can you pls give me the phone No of your dealer tx
            In terms of the rotor cap, is this the distributor cap and if so you unscewed it from the disrt housing (2 screws) and just replaced cap instead of whole disrt body assy.
            pls advise
            • KenG
              • Oct 2006
              • 29
              • Minnesota
              • 1991 Ski Nautique 1997 Ski NautiqueW/ GT 40 2006 206
              Originally posted by laurie88 View Post
              thanks guys
              pls advise
              The rotor is under the distributor cap. Remove screws and remove distributor cap, the rotor is then visible. I'd replace both.
              2006 Ski Nautique 206
              1997 Ski Nautique CB
              1991 Ski Nautique
              • wakebrdr38
                • Jan 2010
                • 17
                • Rockwall, TX
                Had the same exact issue a couple weeks ago. Drove me crazy trouble shooting everything. I changed everything just like you. The very last thing I did was change the cap and rotor and problem completely solved! I had a lot of corrosion and the motor only had 350 hours on it. There was an issue with that GM motor and moisture collecting under the cap. I highly recommend going to O'reilly's to buy the replacement cap and rotor (I think it came to about $60) but it comes with a lifetime warranty. After I had heard about this problem with the distributor cap and no real fix for it I figured a lifetime warranty sounded great!
                  The ignition timing is controlled by the computer. But the distributer has to set "close enough" so the rotor inside the cap is pointing to the correct terminal inside the distributer cap.
                  • laurie88
                    • Mar 2010
                    • 75
                    • model 206
                    misfire
                    thanks guys
                    if i change the distr casp and rotor is it just a csae of removing and replacing or is there sonme adjustment to be made and if so how is this done..cheers
                    • KenG
                      • Oct 2006
                      • 29
                      • Minnesota
                      thanks guys
                      Just a matter of replacing the parts. Obviously the plug wires NEED to go back in the right place.
                      1991 Ski Nautique
                      • ffmedic74
                        • 835
                        • Lexington, KY
                        check your battery as well. If you arent getting enough voltage to the injectors they will not work correctly and do the same thing as you describe.
                        • scuff97
                          • Sep 2010
                          • 52
                          • 1992 sport nautique 2007 SV-211
                          If you replace the cap and rotor only there is no adjustment. if you move the complete distributor you will need to hook up diagnostic tolls to set the cam retard.
                          • thedude
                            • Apr 2007
                            • 451
                            • SW PA
                            As mentioned above, just make sure of which wires go where by marking them 1-8, or however you want to mark them. Its a very easy job, 20 min max.
                            • laurie88
                              • Mar 2010
                              • 75
                              • model 206
                              engine misfire
                              thanks guys im goin to check the distr today.
                              did your engine warning light come on, my doesnt
                              i have the diagnostic tool also so i will give that a try, although since my warning light does not come on i do not know if the ECM will store any trouble codes (dtc)
