Where is it in the boat?
206 fuel tank
Boat: 2001 Nautique Super Sport
\"Dont forget to put the plug in.\"
http://www.planetnautique.com/index....amp;highlight=
Another Ballast InstallTags: None
Unless I'm mistaken, it is under the rear seat. If you remove the bottom cushion(s), you should find a pin on each side (towards the lower end of the back rest of the seat), remove the pins and you should be able to move the "box" that makes the seat (depending on the year, either carpeted or made fully out of fiberglass).
