Engine Cutting Out & Stopping '93
  • NewNauitiqueOwner
    • Oct 2010
    • 6
    • Austin
    • 1993 Nautique
    Hi all,
    I bought a 1993 a month or so ago and had it out last weekend. It was running great below 4000 rpm, ran it up to full throttle approx 4400 rpm. I could tell it was missing a little at 4400 rpm. Turned it off and sat for a little bit. Started backup and the engine just stopped at full throttle after about a minute of running. However it restarted no problem and ran fine below 3500 ish rpm.
    Any thoughts?
    Thank you Brian
  • swooddc
    • Oct 2006
    • 147
    • Gardendale, AL
    What motor?
    First guess would be fuel filter, pumps.
    • Quinner
      • 2246
      • Correct Crafts
      If you have a Pro-Boss with the Pro-Tech ignition it could be a problem w/the Pro-Tech. When mine started to fail on our 93' it would miss and generally run bad at high RPM's & sometimes would not start when hot. If it is the Pro-Tech the conversion is about $500, that is unless you have the EFI.
      Lot's of previous posts regarding Pro-Techs failing here and also on www.correctcraftfan.com.
      Good Luck
