I winterized my boat today. I have a 1999 Super Air. The Drain plug on the front of the Vdrive is stripped. I can get vice grips on it but no room to crank it. So is there a tool that I can go buy? Has anyone else had this happen? Any suggestions are greatly appreciated. Im in Texas so not real stressed about a freeze but it just bothers me.
Don't know of any special tools, but if you pull the rear seat and pull up the floor panel it will give you more room to work on it. If you drained the rear one and cycled AF through the system you will be fine as there isn't alot of water in there in the first place.
JMO2018 Ski Nautique 200 TE, H6
