where are block drain plugs?
  • gride
    • Jun 2007
    • 1441
    • War Eagle
    • 05' 210 team
    2005 ex330 closed cooled. how many plugs/hoses are there and roughly where are they located? if you know what size tools to use that would be a great help also.
  • scuff97
    • Sep 2010
    • 52
    • 1992 sport nautique 2007 SV-211
    The 5.7L engine has a block drain on one side and on the other side is the knock sensor. There is a plug on each exhaust manifold and one plug on the large hose from the circulation pump to the thermostat housing. You should also remove the hose from the trans cooler.
    • G-man
      • Jun 2004
      • 428
      • Allen, Texas
      I don't know the details on draining the closed cooling system but you don't drain the block or pull the knock sensor or you will loose your coolant. Look on PCM's website and they should have a manual that will clue you in.
      Current
      2003 SkiNautique 206 LE Yellow - Black - Silver Cloud
      Previous Fleet
      2006 Ski Nautique 196 SE Titanium - Black- Silver Cloud
      2004 Ski Nautique 206 LE Red - Black - Silver Cloud
      1993 Mastercraft Stars & Stripes 190 Red
      • gride
        • Jun 2007
        • 1441
        • War Eagle
        • 05' 210 team
        is there a perfect seal substitute from autozone b/c i couldn't find it.
        • j2nh
          • Dec 2003
          • 628
          • Spread Eagle Wisconsin
          gride, the engine manual is on this website to download, make it your best friend. If your closed cooling was factory installed then it should have the quick drain kit installed. There are hoses that run to the drain ports on the engine and exhaust system and then combine in one hose with nut on the end of it. Remove the nut and it drains the exhaust manifolds and engine coolant heat exchanger. On a 196 this hose is laying in the bilge of the boat next to the drain plug. Do not confuse it with the "quick drain" oil hose which runs from the oil pan and is usually secured on the top of the engine. With closed cooling and the fresh water drain kit there area ton of black hoses around the engine. Follow each one to make sure you understand how the system works. You might consider marking them with colored electrical tape for future reference.
          After you drain that system you still need to remove two bolts from the pull end of the exhaust manifolds. You may or may not have them on the 5.7, again check your manual. Pull the impeller, replace with a new one, drain the water out and replace the old one, or store the old one in a plastic bag and reinstall it in the spring. Drain the water separator and replace it dry, don't lose the rubber washer. Drain the transmission fluid cooler, there is a nut you can remove to do this or you can just remove the hose. Check for low spots along the raw water line before and after the transmission cooler, lift them as you can to get the water out. Again, this is off the top of my head, the best, and as far as I am concerned only, real reference is the PCM manual which Jeff has made available on this site.
          What are you using "perfect seal" for?
          2018 200 Team H6
          2009 196 Team ZR 409
          2005 196 Limited ZR 375
          2003 196 Limited Excalibur
          1999 196 Masters Edition
          1987 ProStar 190
          • gride
            • Jun 2007
            • 1441
            • War Eagle
            • 05' 210 team
            the manual says to put perfect seal on the drain plugs when re-installing. i can't seem to find any real info what exactly it is and can't find that specific product online either.
            • j2nh
              • Dec 2003
              • 628
              I use anti -seize (NAPA). Nasty silver paste that makes a huge mess if you get it on anything other than the intended bolt/threads.
              2018 200 Team H6
              1987 ProStar 190
              • gride
                • Jun 2007
                • 1441
                • War Eagle
                • 05' 210 team
                no napa here. if i say anti-seize to someone at o'reilly or autozone will they know?
                • j2nh
                  • Dec 2003
                  • 628
                  Yes they will.
                  2018 200 Team H6
                  1987 ProStar 190
                  • maxxwell
                    • Jul 2010
                    • 147
                    • Houston, TX
                    • 2008 Air Nautique SV211 TE
                    Gride,
                    I couldnt get a straight answer for the 2008 engine, but here is what I found out through trial and error
                    For the 2008 330EX
                    1) On either side of the block, there are knock sensors. When removed, coolant leaks out
                    2) Use a 1/2" extension on the V-drive plug
                    3) I used a cresent on the bottom driver side of the heat exchanger
                    4) The heater is also tied to the closed cooling (contains coolant)
                    This is about all I tried, but I work offshore and ran out of time and had to come to work.
                    Hopefully some we can get some answers for these engines, as the PCM manual is not clear
                    Gone - 2008 Air Nautique SV-211 Team Ed - Death by Fire
                    • gride
                      • Jun 2007
                      • 1441
                      • War Eagle
                      • 05' 210 team
                      ya i mean i've looked at my engine, read the manual a bunch, looked at diagrams, etc. im sure after i did it once it would be easier than putting together walmart furniture.
                      • eldercaddy
                        • Dec 2010
                        • 3
                        • San Francisco, California, USA
                        Hi gride . I think there is a substitute but I'm not sure yet. I will tell it to you if I am very sure on it.
