since doing compression test by mechanic my boat has started to missfire at 1700rpm and engine starts shuddering , popping
he did remove only plugs and we cranked engine in each cylinder
he did NOT
REMOVE ANY LEADS FROM COIL or distributor
Disable fuel pump
Has this damaged my coil, (or anything else) as we have replaced everything else and engine still misses but only under load at 1700rpm . we have no engine warn light, boat starts first time, idles ok
pls help
he did NOT
Disable fuel pump
pls help
