Steering Cable lifespan?
  • mf01
    • Jun 2005
    • 515
    • Austin, TX
    I bought my boat 3.5 years ago. About 2.5 years ago, I changed the steering cable. I just thought it was due then, since the boat was 13+ years old then. Now the steering cable is stiff again. I disconnected the rudder, lubed it, and it moves freely. I use the boat 3-4 times a month in the summer and once a month from October - February. The only other thing would be the helm. Do helms ever go bad?
    How long do you get out of a typical cable? It's a pretty expensive item ($277). Does it need to be replaced this often (2.5 years)?
    Previous:
    2011 Super Air Nautique 210
    1994 Sport Nautique
  • teamseal
    • Dec 2006
    • 384
    • Panama city, Florida.
    • 2009 196 ZR-6
    Cable longevity.
    I had to put a cable in my 09 at the end of the summer of 09!! Steering Cable longevitiy IMO depends on how the stars are lining up, in other words I dont think their is a set time limit. I have heard of owners with 20 year old boats and just now changing out their cables. on the other side I have heard of maybe two seasons out of one. A couple of years ago Teleflex came out with the Extreme series rack cable. I have been selling the Extreme cable for replacement in 98 and newer Nautiques. So far no complaints. I also just supplied a new Rack and pinion system for a 90 SN complete with an Extreme cable, it worked out very nice.
    some of the things that can help with cable longevity, keep water out of the bilge, service and lube the rudder port assy. keep all moving parts in the system clean and dry and lubricated.
    • mf01
      • Jun 2005
      • 515
      • Austin, TX
      I saw the Helm replacement to convert to 98+ on white lake. I didn't see the Extreme cable. Do you sell them online? Or where can I get them?
      Previous:
      1994 Sport Nautique
      • teamseal
        • Dec 2006
        • 384
        • 2009 196 ZR-6
        PM sent.
        • erkoehler
          • Sep 2004
          • 94
          • Boat House Chicago
          • 2001 Ski 196 & G series demo
          I think the water in the bilges is really causing premature failure on a lot of cables. With fat sacs, etc. there is a lot more water getting in to bilges these days.
          • ski4evr
            • May 2010
            • 613
            • Bowling Green, KY
            • 2005 SV 211
            Is the "Extreme" Cable available for an '05 211? My cable is really stiff to move.
            2005 SV-211
            • horkn
              • Aug 2007
              • 270
              • WI
              The steering cable is the original one on my 78 martinique. So 32 years for mine so far.
              • snowboardcorey
                • Dec 2007
                • 105
                • Minneapolis, MN
                • Past: 1968 Ski Tique
                This is highly dependent on how much moisture is in the bilge and/or how much gets under the jacket. Pulling the plug from time to time to get the bilge dried out seems to really help with cable life.
                Sold my boat to buy a house, the house is much less fun.
                • mf01
                  • Jun 2005
                  • 515
                  • Austin, TX
                  Now I'm thinking it's random. I pull my plug every time out. I rarely have my boat out for more than a few hours, so the water doesn't sit long. Also, most of the water gets pumped out with the auto-bilge.
                  Previous:
                  1994 Sport Nautique
                  • snowboardcorey
                    • Dec 2007
                    • 105
                    • Minneapolis, MN
                    Maybe you got a bad one, in that somehow water permeated the jacket and corroded the cable inside prematurely.
                    • mf01
                      • Jun 2005
                      • 515
                      • Austin, TX
                      I could have. I believe I got the Teleflex for the replacement. I found it on my statement for around $165 from White Lake.
                      Does anyone know which is better, Teleflex or OEM?
                      Previous:
                      1994 Sport Nautique
                      • shonuff
                        • Sep 2010
                        • 157
                        • Atlanta, GA
                        • '05 SANTE
                        I replaced mine this year. I re-routed the cable to keep it out of the bilge until it reaches the engine compartment. Hopefully this will extend the life of the steering cable.
                        2005 SANTE
                        • gride
                          • Jun 2007
                          • 1441
                          • War Eagle
                          • 05' 210 team
                          get the sealed cable they put on coastal editions.
                          • mf01
                            • Jun 2005
                            • 515
                            • Austin, TX
                            Where can you get the sealed cable?
                            Previous:
                            1994 Sport Nautique
                            • h2oski
                              • Oct 2010
                              • 49
                              • Liberty Hill, TX
                              • 1996 Ski 176, 1999 Air, 1977 CVX-20
                              Sorry, I can't tell you where to get a sealed steering cable, however, Teleflex (OEM?) has a newer design called TFXTREME that's getting some good feedback. You can find them here: http://www.skidim.com/default.asp
                              I have a 1999 Air and always turn the steering wheel all the way to the right when I put her away. This pulls the exposed end of the steering cable assembly back inside the sleeve to try and protect it as much as possible from any moisture in the bildge.
                              Good luck!
