accelaration problem ..exhaust
  • laurie88
    • Mar 2010
    • 75
    • model 206
    400hrs 206 used in salt permananent, replaced exhaust maniflod and now get engine mis/ pop at 1700rpm every time....sound like something is blocked
    we have done lots of research and just waiting for diagnostic tool
    no engine warn light , all gauges ok, starts first time,idles fine, changed all plugs, distr cap, rotor, leads, filters, pumps , oil press sensor, ect, etc, fuel pres ok
    we are now thinking the mechanic could have done something related the the exhaust, since the sympton only started after the change of manifolds
    has anybody experienced this sympton of popping/ misfire under load maybe with damaged muffler, baffles, something broken in exhaust etc..is it common
    tx
  • Quinner
    • 2246
    • Correct Crafts
    Been following your many threads as I am very curious as to what exactly will fix your issue(s).
    You may want to post your problem & description on www.correctcraftfan.com as well.
    Good Luck
      • 2908
      what do the plugs look like?
      popping or backfiring is typically caused by a lean condition. it could be as simple as a cracked hose in a vacuum circuit (if there is one on your boat). My guess is that something got bumped or broken during the replacement, but that's just a guess and it's not great to do guesswork on these.
      The repeatability at 1700RPMs is the most telltale of your description. You need to determine what happens at 1700 rpms, does a channel in the FI open, does a vacuum switch open, does the timing change?
      Assuming it doesn't do it unloaded starts to point me towards a full throttle circuit in the FI. Maybe a coincidentally failing injector, guessing again...
      • laurie88
        • Mar 2010
        • 75
        • model 206
        plugs look ok
        whats the F1
        Where is the vacuum circiut.....up to now cant see any damaged hoses
        boat is model 206 yr 2007
        tx
        • horkn
          • Aug 2007
          • 270
          • WI
          "F1" is actually FI, or fuel injection....
          Shouldn't that boat be under warranty?
          • Andy3535
            • Nov 2009
            • 31
            • Sonsbeck Germany
            This might help
            This Product Information Update supercedes SUP2006-04, Information on Setting CAM Retard PCM 5.0L (Pro Ski) and 5.7L
            (Excalibur) engines, serial number range 470001 through 485993.
            When rotating the distributor on the affected engine, you are adjusting what is called “CAM Retard.” This parameter
            represents the position of the distributor rotor relative to the proper terminal in the distributor cap when the spark is delivered. The
            specifi cation indicated for this engine is 0-4 degrees. If the engine is set at 0 degrees, under certain precise RPM, temperature
            and load conditions, the engine can “crossfi re.” This means the spark jumps to the wrong terminal within the distributor. This can
            cause a slight backfi re or sputtering under this condition. To ensure this condition does not exist, CAM Retard should be set
            between 6-8 degrees on engines between serial numbers 470001-485993.
            This is a correction made to the tune-up specifi cations and should be checked and set to specifi cation during normal service
            intervals. In most cases, the problem does not exist. This is not an update that requires you to have the customer bring the boat
            in specifi cally for this update, it can be simply done during normal tune-up and/or commissioning procedures. A new specifi cation
            decal needs to be installed after the adjustment is made. Contact PCM in order to receive updated specifi cation decals, p/n
            R143170B-U, which indicates the correct CAM Retard specifi cation.
            NOTE: Engines built starting with serial number 485994 have been changed to a new specifi cation (15 +/- 2 Degrees) and circuit
            diagnostics added. These engines DO NOT need to be changed.
            In order to properly set the CAM retard, the following scan tool MUST be used:
            PC Based Diagnostic Software: Diacom Diagnostic Software, Marine Edition, by Rinda Technologies, Inc.
            Available for purchase through PCM, P/N RT0086.
            1. Connect the laptop to the engine’s data link connector.
            2. Per the tool instructions, navigate the tool to view ECM data.
            3. Find the engine parameter labeled “CAM Retard.”
            4. Engine must be running in order to view the CAM Retard value.
            5. CAM Retard value MUST be set between 6-8 degrees. If the value is within specifi cations, make sure the distributor hold
            down bolt is tight.
            6. If the value is outside the specifi cations, loosen the distributor hold down bolt and slowly rotate the distributor until a value of
            6-8 degrees is achieved. Tighten the hold down bolt securely, making sure the CAM Retard value does not go outside of the
            specifi cation. Once the distributor hold down is tightened, verify the value still remains between 6-8 degrees.
            Important: The basic principle that the distributor must be installed into the engine properly still exists. If the proper CAM Retard
            cannot be achieved, check the installation of the distributor.
            7. Clean the surface of the old specifi cation decal and install new specifi cation decal, p/n R143170B-U.
            Engines Affected: 2007-2008 5.0L MPI (Pro Sport) ALL 2007-2008 5.7L MPI (Excalibur) ALL S/N: 470001-4859
            • Quinner
              • 2246
              • Correct Crafts
              Might be worth spending a few minutes double checking no plug wires were crossed when they were re-installed.
              Check the firing order.
              • laurie88
                • Mar 2010
                • 75
                • model 206
                Thanks Andy
                put the diacom on last night eventually
                cam retard was -10.5??. degrees........no fault codes
                presume -10.5 is not right
                how can it slip....how to fix???(new distr maybe)
                my o& m manual says master engine spec 0-4 degrees, as you update suggests, and tune up spec 43-47 degrees.??...dont understand this?
                • scuff97
                  • Sep 2010
                  • 52
                  • 1992 sport nautique 2007 SV-211
                  you will have to hook up Diacom and with the engine running at idle turn the disributor until you reach 6-7 degrees. that should take care of the popping back and engine miss
                  • laurie88
                    • Mar 2010
                    • 75
                    • model 206
                    thanks guys
                    i will try this on saturday with the diacom, fingers crossed
                    • slob02
                      • Sep 2003
                      • 333
                      I did have a "baffle" break in my 1997 muffler and basically blocked the exhaust from getting out completely. Eventually the pressure was to much and cracked a hole in the muffler.
                      2008 Super Air 210 Team
                      2004 AIR 206 Team
                      1997 Ski Nautique 196
                      1993 Ski Nautique SNOB
                      • laurie88
                        • Mar 2010
                        • 75
                        • model 206
                        fixed the prob at last, connected diacom and turned distributor until cam retard was at 7 degrees
                        • Quinner
                          • 2246
                          • Correct Crafts
                          Good news! Curious where you are located that there is no dealer nearby?
                          • Andy3535
                            • Nov 2009
                            • 31
                            • Sonsbeck Germany
                            Great that you found the fault!
                            What I do not understand is why it needs a English man living in Germany to give you guys a tip on where to set your cam retard!!!!
                            This service update from PCM I found searching the internet!
                            Andy
                              This is a note to PN administrators.
                              Threads like this one should have a special place, or pinned to always stay on the top of lists. Setting the distributor is one of those basic things, like checking the fuel pressure, that when random engine problems show up, you need to be aware of.
                              Maybe a category subdivided in to GT-40 engines, Apex engines, Excalibur engines, Python engines, ETC.
