need parts resource
  • mevirga
    • Feb 2010
    • 36
    • Santa Cruz, CA
    need parts resource
    Hi, I had an unfortunate accident with my tower falling forward and landing directly on the stainless steel grab rails of my "99 Air. Very lucky, however, that it didn't even touch the gelcoat, just bent the grab rails. My local dealer simply will not get back to me after numerous requests to have them ordered. Does anybody have any suggestion?
    Thanks,
    Mike
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    White Lake Marine
    White Lake Marine. You even get a discount as they are a sponsor of the site.
    Nautiqueless in San Diego
    • maxxwell
      • Jul 2010
      • 147
      • Houston, TX
      • 2008 Air Nautique SV211 TE
      Second that for White Lake, Dave will source this for you
      Mike
      Gone - 2008 Air Nautique SV-211 Team Ed - Death by Fire
      • mevirga
        • Feb 2010
        • 36
        • Santa Cruz, CA
        thanks guys
        Mike
        • Boardboy
          • May 2009
          • 39
          Grab Rails
          Did you get these grab rails yet?
          • mevirga
            • Feb 2010
            • 36
            • Santa Cruz, CA
            grab rails
            No I didn't. Talked to Dave and he worked on it for me with no luck from the factory. Don’t know what to do at this point. Hard to believe these aren't available since they were pretty standard for many years/models of Nautique after '99. Any more ideas would be great.
            Thanks.
            • AirTool
              • 4049
              • Katy, Texas
              I guess just have them fabricated at a tuna tower shop. Might have to change material.
              • IMPACT-EV1
                • Jan 2011
                • 86
                • indy
                I would just buy some tubing and bend it yourself you should all ready have the end fittings so loosen the set screws pull out the bad piece and use the otherside as a template and make a new one exactly like the old one, they are interchangable now if it's the style that just has the tubing with a stud on the ends buy a new one from west marine and call it a day, pretty easy fix actually
                • SBRS
                  • Jul 2010
                  • 63
                  • Rancho Cordova, Ca.
                  • 2012 Ski Nautique 200 CB (current boat) 2013 Ski N
                  Please give me a call. I might have access to the rails. I will need the length of the rails.
                  Bob - Superior Boat Repair & Storage
                  916-638-3382
                  • mevirga
                    • Feb 2010
                    • 36
                    • Santa Cruz, CA
                    Grab rails
                    Not following you exactly Impact. If I remember correctly, the grab rails are one piece and curved with a stud/flange that is welded, not set screwed. Then a nut fastening it under the gelcoat. Is the stud is inserted and set screwed into the tube sleeve on the underside? The boat is stored 2 hours from my home, so I don't have the exact measurement from stud center to stud center. Can anyone help with the measurment if they have a model Nautique with these rails? Thanks again for everybody's help.
