OK I HAVE A 1999 NAUTIQUE SUPPER SPORT WITH THE FUEL INJECTED PCM 5.8 HO, I HAVE NEVER HAD A PROBLEM WITH IT UNTILL NOW THE ENGINE HAS ABOUT 330 HOURS ON IT, I HAD A BRAIN SNAP AT THE FUEL BOWSER AND PUT A FULL TANK OF E-10 AND RAN IT THAT DAY WITH NO PROBLEM THAN STORED THE BOAT FOR ABOUT A WEEK THEN TOOK IT OUT WITH THE REMAING FUEL IN IT, RAN IT FOR THE DAY THEN RITE AT THE END OF THE DAY IT STARTED TO IDLE REALLY ROUGH AND LOSS A LITTLE BIT OF POWER FROM TAKE OFF BUT ON THE PLANE IT WAS FINE AND AT HIGH RPM FINE IT ALSO STARTED TO SPIT FUEL OUT THE EXHAUST AND YOU COULD SMELL THE FUEL WHILE WAKEBOARDING, SO I SYTHINED ALL THE REMAING FUEL OUT CHANGED THE PLUGS AND THE FUEL FILTER IN THE (F,C,C) FILLED IT UP WITH 95 OCTANE AND TOOK IT OUT TODAY IT WAS BETTER BUT STILL SPITTING FUEL OUT EXHAUST AND THE ROUGH IDLE IS BETTER BUT STILL THERE AND IT TAKES A WHILE WINDING OVER WHEN HOT BEFORE FIRES, I SPOKE TO A MACANIC TODAY AND HE SAID PUT SOME INJECTOR CLEANER IN IT AS THE E-10 COULD OF DISRUPTED THE SPRAY PATTARN OF ONE OF THE INJECTORS AND ITS (DRIBBLIN) FROM A BIT OF **** STUCK THAT THE E-10 HAS DISRUPTED AND THE COMPUTER ALSO COULD OF RE-MAPED IT SELF AND NEED TO RE AJUST IT SELF WHAT DO YOU GUYS THINK
PLEASE HELP
PLEASE HELP
