E-10 fuel problem i think
  • horkn
    • Aug 2007
    • 270
    • WI
    • 78 CC Martinique, rebuilt floor and custom interior.
    Originally posted by shag View Post
    Just wanted to share an experience. early this year, I had to have a fuel pump (inside the FCC) replaced due to severe corrosion. The boat (05 SAN) had just ran out of warranty (about 10 hrs and a few months past) when I had the boat in and serviced. I had been noticing a fuel smell and also had occasional problems with and what I would describe as occasional fuel related hesitation on acceleration.
    PCM agreed to warranty the pump (excellent warranty service) and seemed to come to a conclusion that ethanol in the fuel caused excessive moisture to collect in the FCC, causing the corrosion and problem I was having. Keep in mind that I used ethanol stabil and still had this problem.
    I can't explain why some people have no problems whatsoever and others like myself have bad experiences with ethanol. I just can't seem to understand why we are making engines less efficient..... And gas costs are even higher now than before. I thought that was one of the reasons for going to ethanol-that it would be cheaper at the pump.
    Take care and be safe!
    I hate to say it, but this sounds like another case of ethanol being the scape goat as well.
    I've never heard of a fuel pump going bad directly due to ethanol, maybe because the pre filter got clogged and made the pump run hot, but that isn't really an ethanol caused issue. Granted the FCC is a specific marine and PCM thing, and cars don't have a set up like this, but still that does not make sense to me unless the quality of the pump was not the best to begin with.
    I am happy PCM replaced it under warranty though.
    Without E10 gas, our fuel costs would be even higher. Also, you can make more power out of ethanol than gas, but since it burns differently, it tends to get less mpg, albeit VERY slightly. The rate that engines are getting more and more efficient will negate any side effects of the minimally lower mpg from ethanol compared to straight dinsosaur juice.
    • AirTool
      • Sep 2007
      • 4049
      • Katy, Texas
      Originally posted by horkn View Post
      Also, you can make more power out of ethanol than gas,....
      If the "gas" you are referring to is gasoline, You are 100% wrong.
      • NAUTIQUE-210
        • Feb 2010
        • 13
        • australia
        • 1999 super air
        e-10 problem i think
        ok guys did a fuel pressure check this is what i got out of the fuel rail with the valve on the end( sitting in the boat looking at the rear, right fuel rail) took the valve thred out and screwed my gauge on
        just turn key (reds) 39psi
        ideling 38psi
        2000rpm 30psi
        3000psi 30psi
        then back to idel 33psi stop restart again 33psi never went back to 39psi, only when turned off and reds on back to 39psi
        and yes this was without the prop spinning not in gear.
        what you think ???????????????
          That looks about right. The fuel pressure is influenced by manifold vacuum, it is lower, with high vacuum.
          You cannot load the engine enough without turning the propeller to get a low vacuum, to change the idling fuel pressure much.
          • NAUTIQUE-210
            • Feb 2010
            • 13
            • australia
            • 1999 super air
            Thanks daniel that one load off my mind im gunner take the injectors out tonight and get them cleaned tomorrow then ill give it a run on new years day see if any improvement
            thanks again for your help
              #21
              I am not sure that the injectors are the problem.
              My 1997 Ski Nautique, has over 2308 hours on it, without cleaning the injectors.
              My 1996 Ford Aerostar van has over 176,000 miles on it, again without the injectors being cleaned. Both the van, and the boat, run good.
              My opinion about injector cleaning is this. It is a service, like transmission flushes, and engine flushes, that some auto businesses sell, not because they are needed, but because they really increase the profit for the business selling you that service.
              Have you downloaded the GT-40 service manual form this site? Do that. it has a very good diagnostic section.
              • NAUTIQUE-210
                • Feb 2010
                • 13
                • australia
                • 1999 super air
                #22
                Yes i have the manual ill look at it tonight also i dont pay for the cleaning of the injectors caus i work for holden so ill get the boys in the workshop to do it for me it only cost me the time to pull them out so ill give it a try, so at least i can rule them out, one of the boys in the the workshop said that one injector might be stuck open so its worth a try, it just seems funny that it was running without fault for so long then one tank of e-10 and it runs like a dog, and im not blaming e-10 i might be blaming the cleaning propertys of the e-10 that might have cleaned all the **** out of my tank and (MABY) blocked an injector when passing through but im only guessing thats why i ask these questions on this very helpfull site ill do the clean and report back, as i said cant hurt.
                • horkn
                  • Aug 2007
                  • 270
                  • WI
                  #23
                  I am referring to gasoline. And yes ethanol makes more power than gas does. Now efficiency is another matter, but I am talking tq and hp, not efficiency.
                  • j2nh
                    • Dec 2003
                    • 628
                    • Spread Eagle Wisconsin
                    #24
                    Without E10 gas, our fuel costs would be even higher. .
                    The only reason E10 is cheaper is that it is heavily subsidized by the Federal government. You also have to consider what the use of corn does to the cost of food. All in all the government subsidizing its use and then mandating we use it is a lose, lose for the taxpayer. We pay once at the pump and the second time when we pay Federal income tax.
                    2018 200 Team H6
                    2009 196 Team ZR 409
                    2005 196 Limited ZR 375
                    2003 196 Limited Excalibur
                    1999 196 Masters Edition
                    1987 ProStar 190
                    • horkn
                      • Aug 2007
                      • 270
                      • WI
                      #25
                      I think many here will benefit from reading this about ethanol
                      http://www.ethanolfacts.com/ETHL2008/page.php?pgID=19
                      It does produce more octane, and it's chemical makeup allows it to combust better than gasoline.
                      As far as subsidies, yeah that does help, but when corn has bumper crop years like this year, so much corn is wasted and rots. Rotting corn can be used to make ethanol, where you wouldn't use it for anything else, except for a corn stove maybe.
                      Ethanol can be and is made from switchgrass, algae, and other biomass, including corn stalks and husks. That's stuff that we won't use for anything else. True, right now more ethanol is made from corn than the other options I have listed (and more), because it is cheaper to make ethanol out of corn at the moment. Once it gets more viable to make ethanol from other sources, then those subsidies will go away, unless farmers can't unload their corn crops otherwise. When other crops are far more profitable, those subsidies are helping farmers because you can't grow soybeans every year in the same field.
                      • AirTool
                        • Sep 2007
                        • 4049
                        • Katy, Texas
                        #26
                        For engines where the exhaust leaves the engine in an all gaseous state (i.e. no condensed water), we quantify a fuel's available energy (heat of combustion) by the "Lower Heating Value" (LHV). The LHV for gasoline and ethanol are shown below as taken from the footnoted URL.
                        Conventional gasoline: 18,679 Btu/lb
                        Ethanol: 11,587 Btu/lb
                        So....just to be clear....you are 100% wrong.
                        http://hydrogen.pnl.gov/cocoon/morf/...ing_values.xls
                        • horkn
                          • Aug 2007
                          • 270
                          • WI
                          #27
                          It's a LOT more complicated than simply BTU value. I respect your posts a lot, and this site does not need that either so I won't get into an argument, but I respectfully disagree.
                          Methanol, and Ethanol injected into normal gasoline engines makes more power due to how oxygen attaches to the alcohol, allowing more power to be made.
                          • j2nh
                            • Dec 2003
                            • 628
                            #28
                            Respectflully horkn, I am of the opinion that ethanol as it is currently produced is not a viable alternative fuel.
                            There are strong arguments that when all energy sources are taken into account that ethanol is a net energy loser.
                            3 billion dollar subsidies provided by the Federal government give a distorted view of the true cost of ethanol production.
                            There is no doubt that it is a benefit to farmers, but I question whether they should profit from the government subsidizing production and then forcing me to purchase it and at the same time driving corn prices higher. Something is just not right with this. This problem is made worse by the Federal government not allowing ethanol imports from Brazil, which would drive the price down.
                            Ethanol is not a long term answer to energy independence and in my opinion keeps this country from exploring and implementing better solutions. I am no expert but from what I have read we could achieve our goals by taking a long hard look at using LNG (liquified natural gas) as a fuel for transportation. We have abundant reserves and the technology exists. I would much rather the government invest in this while we work on battery technology which still has a long way to go.
                            2018 200 Team H6
                            1987 ProStar 190
                            • horkn
                              • Aug 2007
                              • 270
                              • WI
                              #29
                              We've been using ethanol mixture gases here in SE Wisconsin for close to 20 years now. And now it finally has now spread all throughout Wi, and most other states. That's pretty darn viable IMHO
                              Yes, there probably are better sources of fuel than ethanol (particularly corn based ethanol), but they would have to be compatible with existing engines. That is the crux of the issue.
                              • SkiTower
                                • 2172
                                • Clayton, NC
                                #30
                                [QUOTE=horkn;151760]but they would have to be compatible with existing engines.[QUOTE]
                                That's the problem, they're not. There's a reason companies are making "flex fuel" systems, to accept this stuff. Tough luck for the rest of us with older cars.
                                2007 SV211 SE
                                Tow Vehicle 2019 Tundra
                                Dealer: www.Whitelake.com
