Nautique 220 Perfect pass module location
  • AndrewC
    • Jan 2011
    • 105
    • Austalia
    • Nautique 220 Team
    Can anyone tell me the location of the perfect pass module for a 220 team nautique. The boat is a 2007 and the perfect pass was installed from the factory.
  • AndrewC
    • Jan 2011
    • 105
    • Austalia
    • Nautique 220 Team
    Ok, so I have since found out that my boat does not have a separate perfect pass module as such. This is because it is housed within the gateway box under the dash.
    Now my question is, what is required to up grade my old paddle wheel system to stargazer? Clearly there is no module to swap, so how is this up grade done?
    I already have the multi line display.
    • shonuff
      • Sep 2010
      • 157
      • Atlanta, GA
      • '05 SANTE
      You sure it doesn't have a separate module? I'm not positive but I thought they always had their own module, even with DBW boats.
      When I upgraded mine to Stargazer I had a hard time finding the module. On my '05 210 it was inside the dash pod behind the gauges. I was confused because I was expecting to find it under the dash. You have to remove the gauge pod to even see it.
      If you already have the multi line gauge all you need is the Stargazer module and GPS puck. Contact Randy Eisener @ Perfect Pass and he will get you set up. reisener@accesscable.net
      2005 SANTE
      • AndrewC
        • Jan 2011
        • 105
        • Austalia
        • Nautique 220 Team
        I thought it might have been behind the gauges too so I pulled the dash apart and there was nothing there except cabling. I traced the cabling from the perfect pass gauge and it went straight to the faria gateway box.
        I have ordered the star gazer upgrade through an Australian dealer and he did want to know if it is a team addition as these and the limited are wired slightly different to the standard edition boats apparently. I hope that he is going to get me the right parts for the job.
        • 2gofaster
          • 671
          Yes, 06+ limiteds and teams had PP inside the gateway box. The STargazer will be a seperate module that you'll have to wire in. You should get a set of instructions and a wiring diagram from PP with it so you can wire it in. Not hard. But kind of a pain in the a$$ because you have to trace wires out of the gateway and harness.
          Shane Hill
          2014 Team 200OB
          67 '13 Prophecy
          • MichaelD
            • Jun 2007
            • 71
            • Raleigh, NC + Lake Gaston, NC
            I know it is frowned upon to re-open a thread from ~5 years ago, but how painful was the wire conversion between PP on Faria Gateway to StarGazer as a stand-alone module?
            • 8urchvy
              • Oct 2014
              • 176
              • La Verne
              • 2007 SANTE 220
              Interested in how this upgrade goes. I'm planning I doing this next year.
