Originally posted by PGMorty
View Post
1990 Ski Nautique
NWCT
Freeze plugs.
TRBenj, you are right that they are not intented as a license to not drain the water. And they are indeed part of the casting process. But they are called freeze plugs because they do offer a small amount of protection against the expanding ice. Your advice should be heeded by all: DRAIN the water!
Personally, I think antifreeze is the only way to go. Drain first, then fill by whatever means you are comfortable with. It removes almost the last shred of fear of deep negative temps. -24* F. is the worst I have seen this year.
Tried and true in the frozen tundra of MN.the WakeSlayer
1968 Correct Craft Mustang
Reader's Digest version
Drain the strainer, block, and exhaust.
I stick a short garden hose in the raw water intake, just past the strainer, then stick that in a 5 gallon bucket of RV AF (pink stuff). Start the engine, and send 4-6 gallons through. Shut the motor off.
Tuck her in for the winter.
Reverse in the Spring, til the exhaust runs clear. No bucket, just a garden hose hooked up to your house.the WakeSlayer
Pythonaholic
Originally posted by bchesley View PostPGMorty,
Lets see some pictures. As a pythonaholic we can never get enough. Have you owned the boat since it was new?
Reverse in the Spring, til the exhaust runs clear. No bucket, just a garden hose hooked up to your house.'08 196LE (previous)
'07 196LE (previous)
2 - '06 196SE's (previous)
Originally posted by PGMorty View PostTRBenj, you are right that they are not intented as a license to not drain the water. And they are indeed part of the casting process. But they are called freeze plugs because they do offer a small amount of protection against the expanding ice. Your advice should be heeded by all: DRAIN the water!
now if the T-stat is removed first then there isn't an issue, but if it isn't then the closed stat forces the water to go in a reverse direction and fill from the top down and can create an air pocket.
easiest and fastest is drain the block, remove the t-stat and fill through the t-stat housing, then the hoses to the manifolds, but to each their own, some methods are not as effect as others and not everyone is in the same climate region so it might not be as important to do an effect job as it would the further north you go.
and you use less anti-freeze because your not waisting it pushing it out the exhaust crossing your fingers it filled the block.
Originally posted by IMPACT-EV1 View Postthis method can lead to parts of the block not being fully filled with anti-freeze. The raw water pump will force the fluid it exit most of the fluid out the exhust manifolds and not into the block and can also create an air pocket in the block too so be warned.
I should have noted that my method is after warming the engine to operating temp.
Definitely to each his own here.the WakeSlayer
yes not the best for a v-drive by any means, DD yes much easier, only risk is opening up the block drains with the engine hot and draining the hot water and then hoping the t-stat doesn't close before you get the plugs back in. But again each their own and i would be suprised if the boat is actually left outside in the elements and survived with the pink stuff and method, but if it has count your blessing.
I am not sure why you would be surprised. It certainly is the case. This is a silly annual debate you seem to be provoking. Spring fever there in mild Indianapolis?
The point is, DRAIN YOUR BLOCK BEFORE WINTER. Adding antifreeze is a great idea, but still fairly new compared to how long combustion engine watercraft in freezing climates have been used..... For decades people simply drained their blocks.
I am merely trying to perpetuate the concept of caring for your engine and not waking up in April with a big old split in the middle of your block. How you get there is a personal preference.the WakeSlayer
Yes draining the block is what is saving you, for fun or maybe piece of mind for some but before you start to winterize (I'm aware it's all ready done in your case) save all of the drained water and measure the volume that comes out of the block, now winterize per your method, come spring drain the anti-freeze block and compare the two and don't get too scared when you see how little of the antifreeze drains from the block.
My point is with your choosen method there is a risk that the block will not get completely filled with antifreeze, does it make a difference freeze wise if it's not full, no it dosen't, so why use antifreeze in the first place? your draing the block completely, so what purpose does the antifreeze provide? after all the block won't crack if there isn't water in it to expand and crack it right? so then it would be to prevent/limit scale forming, rusting maybe? so then if a little metal is exposed within the water jacket it's no big deal then right?
Dude, please...... go get a sunlamp......the WakeSlayer
So long as you drain the block first, it really shouldnt matter much what way you introduce the antifreeze. All of the thermostat housings Ive disassembled allow the block to fill up before dumping out the exhaust, regardless of whether the stat is open or closed.
I choose the pour in method per the PCM manual because its simple, easy and fast. I also usually remove my RWP for 2 reasons- it allows the last bit of water out of it and by storing the impeller out of the pump, it doesnt take a set.
That being said, I only own and work on direct drives- Im sure I would be doing the same as Wakeslayer if I owned a v-drive!
Regardless, you ALWAYS have to drain if you want your block to have unquestionable freeze protection.1990 Ski Nautique
NWCT
