Oil bath bearing changeout
  • ski4evr
    • May 2010
    • 613
    • Bowling Green, KY
    • 2005 SV 211
    I added a second set of disc brakes to the rear axle of my prestige trailer this week (Original dealer must have cheaped out with one set). I contacted UFP about the kit and they were happy to sell the whole kit for around $260. When specifying the type of hub (I had oil bath) they were pretty insistent that I replace them. They were even willing to give me 4 of the trailer buddies (about 20 bucks apiece) for free if I would replace the oil bath assemblies. When I asked why, they said they had numerous failures and the wheels were flying off of the trailers. HOLY CRAP!!!! So needless to say, I now have greased bearings and 4wheel disc brakes. Can wait for the snow to melt so I can drag it around and try them out!!
    2005 SV-211
  • xrichard
    • Aug 2008
    • 669
    • El Dorado Hills
    • 2023 G23
    Did you change out the spring in the coupler? I added brakes to my second axle and didn't know that I had to do this until the guy selling me the parts pointed it out...(at least with a UFP A60 coupler)
    Previous boats:
    2015 G23
    2008 SAN 210
    2002 XStar
    1995 Sport Nautique
    • ski4evr
      • May 2010
      • 613
      • Bowling Green, KY
      • 2005 SV 211
      Yes I did, thanks for checking on me. That actuator is a pain to be such a simple design. Probably was just over thinking it. The rotors also had this black powdercoating on the and had to clean that off as well.
      2005 SV-211
      • xrichard
        • Aug 2008
        • 669
        • El Dorado Hills
        • 2023 G23
        Heh....I thought the same thing about the actuator. Once I stepped back and took a deep breath, it wasn't such a problem-but it was frustrating for a bit.
        Previous boats:
        2015 G23
        2008 SAN 210
        2002 XStar
        1995 Sport Nautique
        • JUST-IN-TIME
          • 293
          • ON YOUR BOAT
          dual disc brakes are super over kill on dual axle trailers
          unless you have an 8000LB boat
          HUMAN BUILT = HUMAN FIXED
          switchbait.com
          • ski4evr
            • May 2010
            • 613
            • Bowling Green, KY
            • 2005 SV 211
            I roasted the rotors on my truck during a long haul through the mountains, so I contacted UFP about their braking system. The engineer there stated their disc brakes are only rated for 3500 lbs. The boat trailer and gear weigh well over 4800 lbs. Could just be the way I drive, but trying to do something to keep from having to change out the expensive rotors again.
            2005 SV-211
            • JUST-IN-TIME
              • 293
              • ON YOUR BOAT
              it is based on axles weight not boat weight
              so 4200lbs per axle is their maximum rating
              you also when need a reversing valve, that could be your problem with eating cars brakes up
              switchbait.com
              • xrichard
                • Aug 2008
                • 669
                • El Dorado Hills
                • 2023 G23
                I talked with UFP tech support before I installed a second set of disc brakes. I was told, at the time, that the 3500lb rating is based on load. So, if I"m 5500lbs (including the trailer), then I need a second set of brakes. I also asked the trailer manufacturer....their line was that single-axle brakes are adequate for my setup in flat-land towing, but for hills and mountains, they'd recommend a second set of brakes.
                Though, immediately after I wrote that I looked at their site and it says: max tandem axle GVWR with one brake axle: 4200lbs. Two brake axles: 6000lbs. So, I'm not sure why I was told 3500lbs. Either way, the rating is based on GVWR...so if your load is over 4200 lbs, then UFP is going to tell you to go with two sets of brakes (or more). Better safe than sorry.
                Previous boats:
                2015 G23
                2008 SAN 210
                2002 XStar
                1995 Sport Nautique
                • TRST
                  • Mar 2009
                  • 44
                  I'm curious how many have had problems or failures with the oil bath hubs.
                  2007 196 Limited Zero Off
                  • Quinner
                    • 2246
                    • Correct Crafts
                    Have an 05' Eagle with Dual Axle-oil baths, a couple hubs have gotten a little milky so I changed the oil, other then that no problems.
                    • JUST-IN-TIME
                      • 293
                      • ON YOUR BOAT
                      its strange because my pacific trailer i wanted 4 disc
                      my boat is around 6800
                      they said twin disc is over kill, based i use a Denali to tow
                      yes if you tow with a pick up, less weight in the rear, then twin disc will be better
                      as for water in the oil hubs, i have seen it more then once
                      to fix it we used blue lock-tight on the seal
                      switchbait.com
                      • AirTool
                        • 4049
                        • Katy, Texas
                        Maybe the 3500 was the payload and the 4200 is the total weight including the axle and wheels. I'm not sure all the gear would add to 700 lbs...but it might.
