I have been fighting a bad miss in my boat ( 2000 GT 40). Well after 6 months at the dealer the mechanic told me that the tach is bad and it is causing the motor to miss fire. Can this be right? I wouldnt think a tach would cuase a boat to misfire but just the opposite the missing boat would cause the tach to be allover the place right?
yes a bad tach can cause motor problems
see it all the time on mercruisers
HUMAN BUILT = HUMAN FIXED
switchbait.com
Originally posted by DanielC View PostThe tach wire just pushes on a terminal on the back of the tach, I think it is a gray wire. Unplug the wire, and see if the miss goes away.
I asked that to the mechanic this very same thing he said it would run with out it can this also be right?2003 226 LE
the tach gets the reading from the negative side of the coil
so what a bad tach does is ground out the coil, making it not fire
i think on your model it is a big plug, you will have to cut the grey wire down a little ways so you can tap back into it
switchbait.com
Originally posted by JUST-IN-TIME View Postthe tach gets the reading from the negative side of the coil
i think on your model it is a big plug, you will have to cut the grey wire down a little ways so you can tap back into it2003 226 LE
